Trunk Ajar... But it's not?
Old Dec 7, 2007 | 09:42 PM
BTU83's Avatar
BTU83
Default Trunk Ajar... But it's not?
On my 84 Corvette, I had the trunk open while listening to music yesterday, then did my usual battery shut off and stored the car. Today I go to drive the car a little, and the Trunk Ajar light was on, as well as the 2 rear trunk lights. I opened and shut the trunk many times to no avail. I drove it to the store, and had to turn the battery off when parking because the 2 rear trunk lights would not turn off, as if the trunk was open. Any suggestions? This is just annoying.
Old Dec 7, 2007 | 09:49 PM
Bob CTS's Avatar
Bob CTS
Take the molding off in the back and readjust or replace the switch if defective. The switch is the one that the black peg on the hatch glass presses. On my 86 the switch got out of kilter.
Edit: For quick testing you can push the switch all the way in with a drill bit or similar to see if the light goes out.
Old Dec 8, 2007 | 09:41 PM
BTU83's Avatar
BTU83
This problem happened so suddenly it seems. Is it hard to replace a switch? Where do I get a new one from?
Old Dec 9, 2007 | 09:21 AM
suks2bu37's Avatar
suks2bu37
It is not hard to replace. Take your time and it will go well. Here is one place to get the switch:
http://www.ecklers.com/product.asp?p...0&dept_id=1177
If you have ever installed any stereo equipment, this is close because you have to remove some trim panels to get to it.
suks2bu37
Old Dec 9, 2007 | 07:13 PM
BTU83's Avatar
BTU83
Thanks for that link. I've never done anything electrical. I've removed the rear panels before while changing the the carpet. Once I get in there, is it straightforward?
Old Dec 9, 2007 | 07:45 PM
CFI-EFI's Avatar
CFI-EFI
There are 4 Phillips head screws holding the black rear hatch window trim panel in place. remove those 4 screws and work the panel out of position to access the light switch. The switch is held in place by two short screws. Unplug the 2 wire connector, and the switch is out. It could hardly be easier. If you don't mind doing without the cargo area lamps for a while, just unplug the 2 wire connector and reinstall the trim panel. That is what I did, just last week.
RACE ON!!!
Old Dec 9, 2007 | 11:12 PM
BTU83's Avatar
BTU83
By simply unplugging it, will it make the trunk ajar light go off?
Old Dec 10, 2007 | 02:34 PM
CFI-EFI's Avatar
CFI-EFI
I never had a warming light. I was walking the dog one night and I noticed the cargo area lamps on. I pulled the courtesy lamps fuse and came out the next day and started fiddling with the switch. After I lubed and tried to "adjust" the switch and saw that I was getting nowhere, I simply unplugged the switch. I'll replace the switch when I get around to it. You can check the schematics in your FSM, but I can't imagine that it isn't the same switch that activates the lamp on the DIC. Try unplugging it an see for yourself.
RACE ON!!!
Old Dec 16, 2007 | 12:30 AM
BTU83's Avatar
BTU83
Unplugging it worked great. Thanks!
Old Dec 16, 2007 | 07:23 PM
CFI-EFI's Avatar
CFI-EFI
Every once in a while, I get one right.
RACE ON!!!
To Trunk Ajar... But it's not?
