Need Thread Size of O2 Sensor...
Old Dec 8, 2007 | 10:12 AM
DCP's Avatar
DCP
Default Need Thread Size of O2 Sensor...
Can anyone tell me the thread size of the stock O2 sensors (after the cats) on an LT1/LT4? I need to buy a plug for my Corsa system for when I do my LT header install.
Also, where might I buy a stainless plug? ( I see a few on Summit.)
Thanks in advance,
David
Old Dec 8, 2007 | 10:57 AM
Aardwolf's Avatar
Aardwolf
Thanks in advance,
David
It says the thread on Summit!
Old Dec 8, 2007 | 11:03 AM
DCP's Avatar
DCP
So all O2 sensors are the same then (18mm)?
If so, I guess that'll make it pretty easy to indentify a plug!
Old Dec 8, 2007 | 11:04 AM
Jamey's Avatar
Jamey
Should be 18mm, same as an 18mm spark plug.
Old Dec 8, 2007 | 11:06 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It's 18mm just like the old style, larger spark plugs. You can use one of them for a plug if you want! You can get an 18mm universal replacement oil pan plug and it'll fit perfectly too, that's what I use. It was a couple of bucks at Autozone.
Old Dec 9, 2007 | 08:48 AM
DCP's Avatar
DCP
Thanks everyone!
To Need Thread Size of O2 Sensor...
