car is bucking
Old Dec 9, 2007 | 10:59 PM
bigwave71's Avatar
bigwave71
Default car is bucking
was coming home from the track the other day and while cruising down the road the car starts bucking then it would run normal for a little then do it again. it did it a while back so i replaced the fuel pump, seemed ok after that till i went to track again.on the way home from track did it again. its not my ignition box because i hooked directly to coil. i replaced coil to eleminate that so im thinkin maybe tps, any other suggestions?
Old Dec 9, 2007 | 11:15 PM
Carpenter's Avatar
Carpenter
CTS (coolant temp. sensor)
In front, bottom of your water pump.
I am having the exact same symptoms.
Replaced my CTS and it didn't fix. Wiggled the connector and voila....runs perfect (until the next pothole, of course ).
So now, gotta find a replacement connector and get ready for Spring
Old Dec 10, 2007 | 03:15 PM
JCD's Avatar
JCD
Am I reading you right that you have bypassed your Ignition Control Module? My car experianced low speed bucking (1st and 2nd gear) about a week before my ICM gave up the ghost.
Old Dec 10, 2007 | 04:06 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
sounds like mine when I needed to replace the cap & rotor on my opti
Old Dec 10, 2007 | 06:25 PM
Demonic85's Avatar
Demonic85
1. Check for codes.
2. Check all the sensors for proper operation before replacing anything.
3. Ohm the ignition coil and have your ignition module checked.
Old Dec 11, 2007 | 01:49 AM
bigwave71's Avatar
bigwave71
where is the ignition module located on a 93?
Old Dec 11, 2007 | 11:56 AM
LouisvilleLT4's Avatar
LouisvilleLT4
Echoing Demonic85's sentiment. You are going to replace everything right down to your frame rails before you fix this problem if you're just going to buy random parts one at a time until it goes away. Do thorough inspections and diagnostics until you've found something for certain. Don't just guess.
To car is bucking
