85 running rough, need some help please :(
Old Nov 23, 2001 | 11:46 PM
Secret Squirrel's Avatar
Secret Squirrel
Default 85 running rough, need some help please :(
My 85 seems to run fine until around 90 degrees celcius and then the **** falls out of it :cry ..still runs but seems to lack(lots)power(does not backfire).
If i pull over and let it cool for a bit it runs fine again untill it gets to around 90.
It does not set and codes. :confused:
Any help appreciated :D
PS: Does anyone know the ACdelco part numbers for an 85 tps and the coolant sensor?
[Modified by Secret Squirrel, 1:47 PM 11/24/2001]
Old Nov 24, 2001 | 01:53 AM
black85's Avatar
black85
Default Re: 85 running rough, need some help please :( (Secret Squirrel)
My car lost lots of power when the cat was clogged. I don't know if it ran better cold though.
Dave
Old Nov 24, 2001 | 09:25 AM
HighHopes85's Avatar
HighHopes85
At 90*C, the ECM does a self test for the ESC module (about the size of a flattened pack of cigarettes and by the blower motor housing on the passenger side).If it fails the self test, your car will run like a dead llama. Usually it sets a code 43, but code 43 can be disabled in the chip, so it might have been done before. If you need to know more about the self test, let me know. -Matt-
To 85 running rough, need some help please :(
