Rack and Pinion
Old Dec 10, 2007 | 04:07 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Default Rack and Pinion
Anyone have an idea on how hard and how long it will take to replace the Rack and Pinion on a 96 LT-1? Went to have the car aligned and they said the Rack has about an inch of play in it. My last alignment in February only lasted about a month so I don't doubt it's the cause...
Is there anything else I should/could replace while I'm in there? Also, do I have any options for the Rack and Pinion? Like a light weight unit, or lower ratio unit from a Z-51?
Old Dec 10, 2007 | 06:05 PM
aminnich's Avatar
aminnich
My FSM, if I read it correctly, makes it sound too easy. Remove the belt and belt tensioner from the top to get to the steering shaft pinch bolt.. Remove the shaft. From the bottom remove two lines, tie rod ends and 3 bolts. I believe it is also necessary to remove the right front wheel/tire in order tob slide the rack out. Just sounds too easy.
Old Dec 10, 2007 | 06:07 PM
DonF's Avatar
DonF
That's about it, I removed both wheels to make it easier to get to. Not a hard job,
Old Dec 10, 2007 | 06:29 PM
shakedown067
Thanks!
Any suggestions on what type or a place to get a new/rebuilt unit?
Old Dec 10, 2007 | 08:01 PM
aminnich's Avatar
aminnich
Your local auto parts store. Your play is most likely the inner tie rods, which are a separate part, but do come with the new rack. I would not replace just the inner tie rods anyway, do the whole thing. Then outer tie rods would be a good idea and then a new alignment will be needed.
Hope all this helps.
Old Dec 11, 2007 | 07:00 AM
shakedown067
Thanks.
Old Dec 11, 2007 | 07:52 AM
DonF's Avatar
DonF
I don't know if there is more then one kind, I bought a rebuilt from a Auto parts chain store, I am thinking around $150.00 but can't remember for sure.
Old Dec 11, 2007 | 09:27 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I think there is only 1 or 2 shops in the country who rebuild the unit so just go for best price.
Old Dec 11, 2007 | 12:27 PM
Sidney004's Avatar
Sidney004
I need a new rack too. I use mine for racing, what do you think of this one:http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
Does it provide better feel or a different ratio?
Old Dec 11, 2007 | 12:53 PM
BADDUCK's Avatar
BADDUCK
I wouldn't buy anything with that kind of warranty disclaimer. Especially from a foreign country.
Old Dec 11, 2007 | 06:25 PM
larryfs's Avatar
larryfs
sounds curious. The later years only had 1 ratio rack, which was the slower ratio. let us know what you decide.
I brought an ebay rack for $90 , but it was a standard rebuild. nothing fancy.
Old Dec 11, 2007 | 07:48 PM
Sidney004's Avatar
Sidney004
I am scared off, it will be a standard rebuild.
Old Dec 11, 2007 | 07:55 PM
larryfs's Avatar
larryfs
the canada thing is more of a hassle, but the rack sounds interesting..
on the other hand, my business exports to CN all the time....
it says it;s a GM offer, but I know GM ran out a long time ago.
Old Dec 11, 2007 | 09:38 PM
klkordzi's Avatar
klkordzi
I replaced the rack on my 85. Along with considering replacing the tie rods this may be a good time to go with poly bushings for the rack also. It realy is not difficult to do and as others have said the new rack goes in surprisingly easier than it comes out. I got mine from Autozone for 158 if I remember. They had both the 21/2 turn and 2 turn Racks. I looked at Rockauto also but you have to ship them your old rack so it ended up being cheaper at Autozone
Old Dec 12, 2007 | 02:14 PM
shakedown067
Does anyone think it's possible to replace the rack with the sport version for an 87? Quicker steering is always a plus!!!!
Old Dec 12, 2007 | 03:06 PM
Matt Cramer's Avatar
Matt Cramer
They're identical except for the internals, so you can easily swap one for the other.
And yes, the warranty disclaimer on that rack is downright scary. It'd be frightening enough to see that label on a lunchbox, let alone a steering rack.
Old Dec 12, 2007 | 03:44 PM
shakedown067
That'd be awesome since the 87 unit is $80 cheaper! They even have the Energy Suspension Bushing kit, which ironicly is the same part number for the 87 and 96. Hopefully they'll take my 96 as a core (has a $5 more core charge) and I'll order my new unit right after christmas.
Old Dec 12, 2007 | 04:07 PM
Matt Cramer
I just realized you weren't talking about swapping a regular one for a sport one on an '87, but I'm not sure there was still any difference. I know for sure the '88 and later racks all swap.
Old Dec 12, 2007 | 04:16 PM
shakedown067
I'll check to see if they have a 88 sport version. I just now thought about the wheel base being different on the 87 and earlier cars too. They have one for an 89, it's a bit more but that's not really what i'm worried about. I'm glad you pointed that out...thanks. Looks like 89 was the last year of the sport rack. the 90-96 all have the same part number. I'm going for the 89 sport rack!
To Rack and Pinion
