Heads/Compression ratio ?
Rel3rd 287rwhp/374rwtq with 170 runners Summit/TFS
http://forums.corvetteforum.com/show....php?t=1710557
mrc24x 319RWHP/380 RWTQ 113 heads
http://forums.corvetteforum.com/show....php?t=1735359
Razor89 300 rwhp 380 rwtq 113 heads
mods in sig
I don't think you'll get 400 crank. Let us know how things go!
being pedantic. Accurate usage of terms is important.
If someone goes under the knife intending to no longer be capable
producing off-spring but had asked for vascular surgery instead
of a vasectomy, then after the procedure he may no longer have
issues with varicose veins but he will still be fertile.
In the same fashion, if he asked to have his heads milled when
he meant that he wanted the valve seats cut, then when the heads
came back from the shop the end result would be different than
he had intended.
I have no reason to doubt that you know the difference between
milling the heads and cutting the seats. Why be exasperated if
someone points out that the wrong term happened to be used?
Edit: changed vericose to varicose.
RACE ON!!!
RACE ON!!!
Using the same DTL factor, mrc24x's 312 RWHP becomes 390 CHP.
(Note that his engine has the PM rods. Also, my vote is that the TF heads
have a leg up in terms of capacity over his TPiS D113 heads.)
Drivetrain loss values for RWD cars range between 17-24%. Variables
like A4/M6, condition, set up & ect will affect where a particular vehicle
lies within the range.
RACE ON!!!
RACE ON!!!
RACE ON!!!
I and people I know used head gasket thickness to lower compression
back in the day. At the time, we didn't know or understand about the
importance of squish or quench distance, all we knew was that premium
leaded fuel was becoming harder to find and we grasped onto what seemed
like a solution that wouldn't require us to pull the engine and invest money
we didn't have in making it able to run on the fuel we could find.
Later I learned about quench and this knowledge helped to explain why
the results of increasing and stacking gaskets on my BBC didn't have
the full benefits I was expecting at the time.
Doubters should pick up a copy of Sir Harry Ricardo's book, "The High-Speed
Internal-Combustion Engine", ISBN-10: 0216890268. You won't find it
readily at Amazon, but it is available from Ricardo Engineering
RACE ON!!!
I did find all that information informative. Thanks for those who posted.
I just found it amusing that after a long and detailed discussion of quench, it barely fell off the first, maybe second page and it came up again.
When it pretty much never came up before.
