96 roller rockers...
Old Dec 10, 2007 | 11:31 PM
aajj1987's Avatar
aajj1987
Default 96 roller rockers...
i have a 96 corvette with an lt1. i know on a lot of the f bodys you have to get different valve covers to run 1.6 rr. i was wondering if thats true on the corvettes to? or can i keep stock valve covers and put 1.6 rr on it? any help would be appreciated.
Old Dec 11, 2007 | 08:11 AM
djxib's Avatar
djxib
The original rocker covers on my 1992 LT-1 were modified to accept roller rockers. The mods looked like they were made with a Dremel. My aftermarket covers accept RRs without modification.
Old Dec 11, 2007 | 08:30 AM
blue94's Avatar
blue94
It is a simple modification, just grind or cut off the drip tabs inside the valve covers, don't break them off or you risk a hole in the cover. Use either a dremel with a small cutoff wheel and cut them off. The stock cover will then work just fine.
Old Dec 11, 2007 | 05:49 PM
pr0zac's Avatar
pr0zac
i have comp pro mag's that fit fine under my stock 96 valve covers.. and the stock crane golds fit fine under there too
To 96 roller rockers...
