I generally drive the car pretty easy (95 LT-1 coupe auto), but on the occasional hard acceleration from a stop, there is what feels like a leftward "shift" at the rear just before the tires grab. It is not tire slip since this happens just at the instant before traction is transmitted to the tires. If I bring the car into my local guy, can any of you suggest what he should be looking for?
well from driving in another car that has bad shocks and springs. Id say MAYBE that when you hit you gas hard since your rear end sinks. It might be pulling in the direction of the spring or shock that is bad. the bad one will be lower than the good one causing pull
Mine does the same thing. It started after some mods and the shift kit install. I think this is normal.
I guess it is possible that this is one of those "normal" quirks with these cars as it seems that I have had this "problem" for at least a few years. I had originally thought it was a traction thing (one tire being stickier than the other) but since I have been paying attention more, it definitely happens prior to the tires grabbing. This seems like the same category of quirk as when I drive over a small bump and the car hops sideways (ever since I owned the car).
Check to make sure the c-beam is tightly clamping the differential. There are only two bolts and some glue holding it. It could be shifting if it is loose.
Hate to sound dumb but do you have any pics or sketches of this arrangement?
That's what I'm thinking also. Mine sometimes has a little rear shift to the left even with ASR on but the ASR flashes and catches it before it goes sideways. It's more noticeable when traveling across lanes or if the wheel is not completely straight. I figured it was just a result of hp and hard shifts.
The rear end shifting under acceleration, shifting, or anything like that is NOT normal. I would check the C-beam bolts at the rear and the transmission as suggested above. My car or the automatic 95 I had before do not exhibit any of these problems.
To the original poster asking about he C-beam, I have no photos to post, but the C-beam connects the rear of the transmission to the differential housing. There are two bolts at the front and two at the rear. I cannot remember for certain, but I think you'll have to drop the exhaust to check the ones in the front. This connection of the trans and differential needs to be tight.
Right! It's really tucked up into the tunnel so you will need to crawl under there to see everything. If these bolts on the nose of the differential and the tail of the transmission work loose then the differential can flex and cause the movement you are talking off. Someone (can't remember who but do an internet search) makes what they call beam plates to distribute the clamping force of the bolts to a larger area to help prevent this problem. Check the torque on the bolts and make sure they are as tight as you can get them.
For the sideway lurch, you need to be thinking about the bushings in the 4 Dog Bones If they are worn out your rear wheels are "Steering" for you.
This will also give you a feeling of the rear shifting around during hard cornering.
Sadly, the busings are a few bucks but they need to be pressed in the Dogbones. The Dogbones are about $45 each at the Stealership. There are Two per side.
Thanks for all of the replies. Maybe I am noticing it more now since I have gotten into the habit of turning the ASR off. The next time I bring the car in for oil change I will ask the guys to check the trans-to-differential connection as well as dogbone bushings.
