Q about dash and ECM
Old Dec 12, 2007 | 11:24 AM
Demonic85's Avatar
Demonic85
Default Q about dash and ECM
I really like the digital dash on my '85, but i've noticed that under hard acceleration it skips quite a few numbers, not exactly smooth. I've read that they switched to a different ECM in '86 that reads data much faster. Would the faster ECM improve the speed of the dash gauges or do they work separately?
Old Dec 12, 2007 | 11:42 AM
Electricblue80's Avatar
Electricblue80
They work seperately. The 85 and 86 also use different ECM's. You may want to start by cleaning the connections at the digi dash and the grounds for it.
Old Dec 12, 2007 | 11:47 AM
Electricblue80
These are the different ECM's for different years
5.7 V8 CFI ("Y" body).........1226026 (84 vette)
5.7 V8 TPI “8” L98 (“Y” body)......1226870 (85 vette)
5.7 V8 TPI “8” L98 (“Y” body)......1227165 (86-89 vette)
5.7 V8 TPI “8” L98 (“Y” body)......1227727 (90-91 vette)
5.7 V8 TPI “P” LT1.......16159278 (92-93 vette)
5.7 V8 TPI “P” LT1.......16188051 (94-95 vette)
5.7 DOHC V8 SFI “J” LT5 (ZR1)......1228331 (90-91 ZR1)
5.7 DOHC V8 SFI “J” LT5 (ZR1)......16163993 (92-95 ZR1)
5.7 V8 TPI L98 ("F" body) Camero.......1227730 (unsure of years)
Old Dec 12, 2007 | 12:07 PM
rick lambert's Avatar
rick lambert
That's an excellent question to pose to Gordon Killebrew. His number is 1-800-398-3883. I think he charges $10. for the call and $3.00 per minute, my bet is he could answer or steer you in the right direction in one minute.
Each one of our vettes have somewhere between 24-27 grounds, so good luck checking all those. One thing I'd probably have checked is your alternator, simply because your symptoms seem to show up "under hard acceleration".
Old Dec 12, 2007 | 12:09 PM
Demonic85's Avatar
Demonic85
I searched Youtube but even the ones on LT1 cars are slow. I guess thats just how LCD gauges work.
Old Dec 12, 2007 | 12:42 PM
RRT vette's Avatar
RRT vette
On my 86 there are three ground for the digital dash.
Two on the 32 pin connector (D1 and D3).
One on the 24 pin connector (B1).
If the digital cluster is cutting out or showing an unusual display, I would check and clean the grounds and check C16 (Bat voltage) and D16 (Bat voltage).
If it's just slow as the youtube clip, then I wouldn't worry about it.
Old Dec 12, 2007 | 12:46 PM
rick lambert
My quote on the number of grounds came directly from Gordon Killebrews book. The display on the 87 works just about like the Video.
Old Dec 12, 2007 | 03:09 PM
Matt Cramer's Avatar
Matt Cramer
I've got an '86 digital dash (unless someone swapped it out), and it's slow too.
To Q about dash and ECM
