My car developed an oil leak around the front of the engine. The tech went into repair and called me and said "you need a new water pump". The water pump was replaced by the original owner just before I bought the car maybe 10000 miles at the most.
I go by the shop to see what was actually wrong and they show me a greasy brown area on the water pump weep hole. It does not appear to be coolant (green) colored. Do I really have a problem? BTW the Opti was dry!
What's behind the o-ring seal on the waterpump itself? Is it oil? There's a chance that that seal is gone, and I think that it's recommended to replace the water pump rather than trying to put a new o-ring in. Might be totally wrong though.
Either way, there could easily be oil coming from the timing cover where the water pump mates up. So if what you saw was indeed oil and not coolant, there's a chance your water pump isn't the issue.
Nothing on the o-ring/seal on the rear of the water pump. The water pump worked fine other than the little bit of brown stuff around the weep hole!? I do have a faulty seal but no on the pump itself.
Shop is telling me nothing should come out of the weep hole. Anything showing up brown(rust), green, or anything is a siign that it is failing. Sound correct?
yes
unless....the waterpump drive seal is bad & it's leaking down from it (which I doubt) because it would drip down around the opti instead of the water pump front. Atleast thats what it did to me.
If it's coming from the weep hole....bad internal seal in the waterpump.
If they're going to replace the waterpump (from my experience) replace the drive seal. I didn't the first time around...it leaked....& I had to pull it a second time to replace it after it went bad.
If the drive seal leaks it leaks oil, right? If that is the case, then that is what started this whole fiesta! I had oil leaking down the front of the engine...
Yeah but it would be hard for that oil to make it all the way from the engine front cover to the water pump weep hole... it would have to travel the whole way along the spinning driveshaft to make it across. As rg951 said, the oil would most likely flow down out of that seal along the front cover instead, all over the Opti.
I may have you confused. The first sign of trouble was oil under the car. No Coolant! Since this was a new engine I immediately thought that I had a seal problem (improper install?).
When everything started coming off the car the tech spotted the leakage out of the bottom of the water pump at the weep hole. So I got double whammied!!!! Leak #1 Drive Seal-Oil and Leak #2 Water Pump weep hole-Coolant. It is not getting mixed together at any location.
I just did not think that the water pump was a problem. Nice surprise!
I just got finished replacing all gaskets/seals on my 95. The bottom weep hole of my water pump had that stain on it too. Did not worry me a bit. If I were guessing I would say that the water pump seal was improperly installed. More times than not it seems when being installed the leading edge of the seal gets rolled back out, instead of coning in...if that makes any since.
It is not uncommon to temporary get a little piece of junk between the seal mating surfaces. They usually leak a little and go away. If the seal is worn it just gets worse. My truck leaked about a nickle size puddle on the floor four or five days in a row and then quit. That was three years ago. My 93 shows signs that it has leaked sometime in the past but it is dry now. Later! Frank
