Maaco Paint Job!
It's really quite easy to work on, although I haven't had to do anything substantial in the 2000 miles since the swap.
Performance wise it's similar to a stock L98 (it'll lay waste to my 84 Vette). I also intentionally left it looking as stock as possible save the trunk decal "2M8". The exhaust was custom fabbed by a local shop....quiet at idle, throaty when you stab the go pedal.
The Honda boys never see it coming.....they do, however, see it going
-- Joe
Orange peel and overspray got everywhere.Tape lines is where the paint peels fastest with time.
A few points to consider.
1) A C4 isn't like an older vette. Older vettes suck to prep because they are made out of fiberglass. I've been working with fiberglass since I was a kid (restoring + painting speed boats). A lot of guys won't take in a "corvette" because of the fiberglass issue. Some bodies are so bad nothing will stick to it.
C4's are made out of SMC. SMC is very easy to work with. SMC filler bonds perfectly, SMC does not require epoxy primer/sealer like fiberglass, and almost any panel can be bonded and reshaped with ease.
I wouldn't hesitate to have a C4 painted by a maaco once I've interviewed the painter. As long as the body is cleaned + degreased properly, sanded, primed, and painted within spec the job will look just fine and last. I have an 'friend' who owns a maaco, and I'm on pretty good terms with another guy who owns another local maaco. I know both of their painters very well, and I've had some pretty good conversations about 'the business'. If you pay $400 for a singlestage paint job you get a da scuff, a quick shoot, and off you go. Everything is taped off. Overspray on the wheels is common. If you want a good 2 stage paint job, the price for the spray is around $1400. $200 for body cleaning and degreasing, $200 for painting inside, and hourly for dissasembly / reassembly if you want things taken off (based on book
estimates for R&R). A "good" paint job at maaco assuming you do NONE of the work yourself will still run close to $3000.
Here is some snapshots of my restoration of a C4:
http://members.cisdi.com/~anesthes/projects/sanding/
-- Joe
Joe...the Fiero never had a factory targa top. They were offered with a dealer installed T-Top option when they were new. These can be tough to come by, but not impossible. They show up on eBay from time to time, or you can post on Pennock's Fiero Forum in the mall section with a WTB ad.
http://Fiero.nl
Of course, customizers have done targa setups and even convertibles.
The most desireable Fieros are the '88 models, the final year they were made, due to the improved suspension. All model years can be fitted with a multitude of different V8 and transaxle setups. The 84's are a little more challenging due to the location of the C500 harness plug, but nothing treacherous.
If you've ever thought about doing a V8 Fiero, do it! The cars can be had for next to nothing, and you can either do the swap yourself of send it off the one of the following guys to do it for you. If you do the work yourself, you can build a fast Fiero for under $5K. Picking on ricers is particularly fun.
but before long you'll be seeking out more interesting prey. At the track, of course.V8 Archie.
The Fiero Factory.
Thread hijack over....back to the regularly scheduled Maaco bashing.....
I just got it back from a full paint job AGAIN this time they had it 6 weeks and is still isn't right. There is overspray on the fenders, and it needs to be wetsanded in places .. yada yada yada..... I sicked Maaco National on them to no avail and turned them in to the Better Business Bureau to get my money back... we will see. I also have the 5 year warranty. the local dealer here says he will no longer warranty any vettes. Hell just don't paint them!!
Chick
I can't resist. I am an auto appraiser and go into hundreds of body shops on a regular basis. Maaco will vary tremendously depending on the location. They are a franchise. The end result will also depend on what else is going on in their shop when your car is there. Many Maaco's have small work areas. There is a prep station where cars are getting scuffed down & taped up (everything gets taped at Maaco unless you pay for R&I (remove & install)). All lamps, mldgs, handles, emblems, wstrips, bumpers need to come off for a proper paint job. If you pay Maaco to do all this youll find they end up no cheaper than any other body shop. If you do it yourself, why not then take the car to a real shop?About 3 feet from the tape and R&I going on is the scuff/sand prep area where there are cars getting sanded, minor bodywork, etc. putting dust and paint into the air. Next stop is the booth where the car is sprayed, then baked at higher heat than than paint Mfg. recommended temp for less time than paint Mfg. suggests for a supposed quick cure that really overcooks the surface without letting the paint underneath properly cure or breathe, resulting in adhesion issues, bubbling, cracking, uneven paint over time.
Then your car comes out of the booth, with the paint still super soft & sticky due to the short bake time. Meanwhile Jose is still going to town with the da on the car 5 feet away, sending dirt dust body filler and other color paint through the air where it gets to settle onto, or rather into your curing paint where it will remain forever. Oh, I forgot to mention that since the paint booth doors are constantly being opened (Maaco will paint 10 or more cars a day per booth as opposed to a body shop that may put 1-2 through a booth in a day) there is all kinds of dirt & snot inside the booth too that already got into the paint.
While your car sits so that the floaty air junk can stick to it well, then next critical Maaco paint job phase begins. I know this from experience, because it was my job for one day a long time ago. A kid making minimum wage with a full set of permanent markers, one being somewhat close to your cars color, and a whole set of black ones in different tip styles, 'details' the paint job. The colored marker is used to fill in all the areas where they overtaped and therefore got no new paint to the intended surface. The black ones are used to cover the overspray on all your mldgs and weatherstripping.
Then begins the final, and most critical phase of the Maaco paint job. As my manager for a day put it:
"If the rims and tires are shiny, they dont even look at the paint".
SO, the min. wage punk hits your wheels with some simple green on a rag, then armor alls the heck out of the tires so you wont look at the paint, does a big burnout and parks it outside ready to deliver. Ta-Daa....one fine Maaco job.
Notice that Maaco will never refer to themselves as a body shop. They choose words very carefully and refer to body shops, but only when discussing the competition.
All this being said, they are franchised so it could be very true that some folks have gotten good results form their local Maaco. there is one near me that has a pretty good rep. BUT, the key thing to remember is that if you are doing the prep and removing all the mldgs, handles, etc. getting your car painted at a real body shop who will very likely have a much better painter (Maaco pays their guys the least $$ and based on meeting production goals, so the good painter who is meticulous simply wont work there), and who will bake the paint properly then isolate the car from the dust & dirt of the shop better, then color sand & de-nib it instead of using markers on it, will cost no more than Maaco.
Shop it, you'll see. Paint material costs what it does- when a body shop quotes you more than Maaco it is beacuse they pull everything off that needs to be pulled off.
Bumper covers are a perfect example, especially on Vettes. Maaco IS NOT gonna remove your rear bumper and pull everything off it to shoot it. A body shop will. Why? Because when the plastic cover expands & contracts at a different rate than the body panel next to it, the globbed in paint that settled into the gap between the two will eventually crack, and begin to peel. By pulling the cover off, the paint can be properly applied and 'broken' + flex additive mixed into the paint for the plastic cover to allow for the additional expansion/contraction.
If you bring your car to a body shop in pieces it will cost no more than Maaco and you will get a better result anyway. Period.
Besides, your local family run bodyshop has likely been there a lot longer than Maaco, run by the same folks, and will be there run by the same folks for a long time. Go to your Maaco once a year and you'll see a complete set of new faces. Hmmmm.....
Chick
I'm sure some shops stink. I know the local shops I've worked with will do what they say on the repair estimate. If you have any questions, visit your local shop. If you find 5 cars apart than you know he's full of it.
Also, the whole opinion of the shop size sounds like his local shop is at the end of the trailer park. Around here the local maaco's are in huge buildings, have numeroues repair bays with frame machines, have a few paint booths.
-- Joe
So your saying you went to a maaco. He told you he wouldn't shoot your car for $500, but since it was a corvette (which is a nightmare) it would be around $5,000? Sounds right to me. Wheres your gripe?
This is the problem with consumers. They want to pay $500, but get a $5000 paint job. When the shop DOES agree to shoot the car for $500, they complain about the quality. When the shop says they will do it the right way, and it will be $5000 the customer complains that it's too much? You guys are crazy.
I have compeletly stripped down, and refinished my Vette. the bodies Suck. End of story. Soo many hours into mine, materials, etc. $5k is dead on.
-- Joe
The same people that want a "deal", or a "discount" are the biggest chiselers and crybabies when they realize they got what they paid for.
That goes for any "service"...Ive learned over the years to walk away when I run into them. Nothing but f'n problems.
"Good work aint cheap and cheap work aint good"
now with that being said, would i have my corvette painted there? if i was going to keep the car then the answer would be of course not if i was just wanting to get some color on it for the time that i did have it of couse i wouldnt think twice.
-- Joe
-- Joe
Goin' to maaco? See if the spray bay has a hygrometer anywhere, and check the air filter in the room too.
Ask them about the volume and pressure regulators of the sprayers. HPLV is best, I think. Do your homework.
