Questions for LTX Engine Builders
Old Dec 14, 2007 | 12:42 PM
Buddyvette's Avatar
Buddyvette
Default Questions for LTX Engine Builders
What tool do you use to prime the engine with oil? The tools I have seen are for use with standard distributor engines. They have a long shaft and are supported at the intake manifold.
Is the crankshaft hub supposed to contact the crankshaft timing sprocket or is there a gap between the two? If there is a gap, what is the specified dimension?
Old Dec 14, 2007 | 01:23 PM
kalister1's Avatar
kalister1
I have not used one, but, I saw a tank on TV that held oil under pressure. This tank was used to push oil through the engine prior to every start up.
I think it was on the "Two Guys Garage" show?
Old Dec 14, 2007 | 02:32 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I prime my oil pump with Lubriplate 105 before installing, pre-filll the oil filter and of course have lubricated everything else already as it went in the engine. Then I disable the ignition and fuel systems and spin it over until it's got oil pressure, shouldn't take but a few seconds at most. Hook it back up, turn the key and fire it off.
Old Dec 14, 2007 | 03:30 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can use the standard one if the intakes off.
Kind of a PITA though.
Old Dec 14, 2007 | 03:35 PM
FD2BLK's Avatar
FD2BLK
Pull the intake, remove the drive gear assy and you can prime it with a Std SBC prime tool, I made mine from an old HEI distributor I cut up
Old Dec 14, 2007 | 04:44 PM
RichS's Avatar
RichS
I prime them before I install the intake.
Old Dec 14, 2007 | 05:15 PM
96GS#007's Avatar
96GS#007
Old Dec 14, 2007 | 05:16 PM
Greg Gore's Avatar
Greg Gore
I needed to prime one with engine completely together in the car once so I used a Motive Products pressure bleeder for brakes. Put a fitting on the end of the hose and screwed it in the oil pressure sending unit mounting point, filled it with oil and pumped up the pressure and prevented a dry start.
The damper hub is designed to seat against the side of the timing gear. There are two different crankshaft keys used on LT1/ LT4 engines. The keys are notched and the depth of the notches is different. Basically the key for 96 has a short shallow notch and 92-95 has a deeper longer notch. If you use a key for a 96 on an earlier version the damper will interfere with the key while it is being pressed on. Damper hubs are different also and not interchangeable due to 96 having the OBD-II crankshaft position sensor.
Old Dec 14, 2007 | 05:20 PM
neat's Avatar
neat
If you just use the standard tool for an SBC, you'll only prime half the engine. You need a collar to simulate the distrubutor or the oil won't make it to the other side of the engine.
Old Dec 14, 2007 | 05:58 PM
Buddyvette's Avatar
Buddyvette
I'm not familiar with Lubriplate 105. What is it and how does it help with the oil circulation? Sounds like the easiest way though.
Old Dec 14, 2007 | 06:01 PM
Buddyvette's Avatar
Buddyvette
That's what I was wondering. Without the intake manifold to hold the tool's collar in place, how do you keep the tool's blade engaged in the oil pump without the shaft flopping around and hitting the gear on the cam?
Old Dec 14, 2007 | 06:08 PM
Buddyvette's Avatar
Buddyvette
I'm putting an aftermarket Cloyes double roller on an LT4 with an aftermarket Eagle crankshaft and am worried about eliminating the reluctor ring as it does not match up to the Cloyes gear as it does the stock gear. I'm cutting the hub for the key, but I'm not sure if this is going to be OK without the hub in contact with the gear.
Old Dec 14, 2007 | 06:43 PM
Corvette Kid
105 is a general purpose engine assembly lube, a lightweight white lithium grease. It provides the oil pump with instant suction as soon as it begins to turn. Thick oil base products such as STP oil treatment and many similar products also hang in there pretty well as a general assembly lube and pump prime. The lithium grease is much "neater" though and has served me well through hundreds of engine jobs, whether performance or stock gas engines or HD diesel truck engines. It mixes instantly with the oil and won't cause any circulation problems.
Old Dec 14, 2007 | 07:39 PM
Greg Gore's Avatar
Greg Gore
The hub has to seat against the side of the crankshaft gear, you can't attempt to have a gap there. Are you keeping the crankshaft position sensor or are you eliminating it? Is so then you will need the earlier damper hub which is longer.
Old Dec 15, 2007 | 09:02 AM
RichS's Avatar
RichS
My "tool" is a old distributer I ground off the cam gears, cut off the alum top and removed everything so just the shaft is sticking up to fit on a drill. I've used it fo 20 years on alot of motors.
Old Dec 15, 2007 | 12:17 PM
aboatguy's Avatar
aboatguy
Me too!
Old Dec 15, 2007 | 12:22 PM
aboatguy's Avatar
aboatguy
My SBC primer works, there's a collar that fits in the block and provides enough oil to prime all the lifters.
The blue collar that you see is for the top of the intake, but the lower collar sits in the block and centers the drive in place.
To Questions for LTX Engine Builders
Old Dec 15, 2007 | 12:28 PM
96lt4c4's Avatar
96lt4c4
I did the same thing, just grind the gears off
Old Dec 15, 2007 | 04:48 PM
prism_kiter's Avatar
prism_kiter
Default im keen to mod my old spare dist into this prime tool made
hi there fellas,
i keen to turn my spare old distributor i have into this oil prime tool as well.
richs,aboatguy or 96lt4c4 could please show us a picture of your modded prime tool you made from a distributor please ?
just wanted to see exactly where on each end to start cutting /grinding thats all on the dist.
or where can i buy one of these prime tools from please ?
Old Dec 17, 2007 | 08:43 AM
5abivt's Avatar
5abivt
drill a hole in the back of the manifold yourself similar to a LTX manifold conversion for a rear dizzy. make up a plate and just cover it up when ur done.
