relay clicking sound
Old Dec 15, 2007 | 01:32 PM
reeferdale's Avatar
reeferdale
Cruising
Default relay clicking sound
My 91 vert (L98, climate control) is in the garage for the winter, it has only been stored for about a month. I went out to the other day to start her up an run around the block a few times and the battery was dead. I pulled the battery out and charged it, the car started right up and I did a few final burnouts of the year around the subdivision. I put her back in the garage and covered her up.
A few days later, as I was walking into the garage, I heard a ticking/clicking sound coming from somewhere. I traced it to the vert. I pulled the cover off and opened the door. The clicking was coming from under the hush panel on the passengers side. When I opened the door, the interior lights did not come on, but when opened the hood to disconnect the neg battery cable, the under hood lights did come on (don't know if this matters at this point)
I have not pulled the hush panel yet to see which relay it was, I am going to open her up and try to determine which relay was clicking (if it still clicks when I connect the battery back up). If a relay does not click when I re-connect the battery, I will leave the cover off so I will have quick access to the relays when/if they start to click again and I guess I will have to wait until it happens again.
I was wondering if anyone knows what would cause a relay to click like this?
I assume this is what contributed to the battery draining so fast. I don't mind replacing a relay, I am just wondering if there is something else I should be looking into as well or if there is a way to determine which relay was originally clicking?
As always any tips or info is greatly appreciated.
Old Dec 15, 2007 | 01:38 PM
Yellow2015's Avatar
Yellow2015
You might try pulling fuses to see which circuit the relay is on........
jmho
Old Dec 15, 2007 | 01:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
Its the battery, when they are weak youll see all sorts of weird things like that. Most common is relays clicking like you said. Toss a new one in, problem solved.
Old Dec 16, 2007 | 01:58 AM
85 500 horse's Avatar
85 500 horse
I read your post, looked at your Forum screen-name and wondered if you actually heard the noise or just had an out of body, sound illusion.
Seriously - as mentioned, throw on a new battery and you should be good to go. If I were you, I'd get a float charger. Don't get a trickle charger. An automatic battery float charger is different than a trickle charger, since the float charger senses a battery’s full state and does not overcharge. Trickle chargers send one or two volts continuously to the battery and can, eventually, overcharge and/or gas the battery.
There's a zillion brands out there with a zillion different prices, so read carefully before you purchase.
By the way, there's absolutely no reason to remove the battery to charge it. With the lower end trickle/float chargers on the market, you need to be real careful not to inadvertently reverse the cables. On a mid to high end charger, if you hook it up backwards, no damage will occur as it/they have built in safety devices/precautions which prevent the unit from working (or blowing up your battery).
Old Dec 16, 2007 | 08:12 AM
Can86Z51's Avatar
Can86Z51
I agree about a 'float'-charger(Battery Tender?) for your battery during storage! If your battery has gone dead over a month, as it probably has on an earlier C4, - it should be replaced with a fresh one. The 'low/no-Maintenance' batteries tends to get irreversably damaged when they go dead over a long storage, particularly in cold weather. You might be able to jump/charge a dead one back to life., but it will then have a short life, and possibly cause other problems(electrical) along the way.
Old Dec 17, 2007 | 09:32 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's possible that is the horn relay activating from the VATS system IF your horns are disconnected. If your horns are working that is probably not it since the horns would blow. I guess if the relay operated for days it could pull your battery down.
Old Dec 17, 2007 | 04:26 PM
1badc5GoStrong's Avatar
1badc5GoStrong
No overcharging here with this float/trickle charger:
http://www.harborfreight.com/cpi/cta...emnumber=42292
Old Dec 17, 2007 | 09:09 PM
jfb's Avatar
jfb
Never Ever let a lead acid battery sit for long periods (4+ wks) doing nothing, even disconnected. It ruins the battery because the battery self discharges (yes, even disconnected) and lead sulphate forms on the plates and this isn't reversable. The relay you hear clicking is the horn relay being operated by the theft detterent module which doesn't work correctly on low battery voltage and cycles the horn relay. The battery is so dead it won't work the horn. Get a battery tender which only charges the battery when it detects a 10% drop in battery capacity and then turns off. Your battery will then have a normal life and be fully charged when you want to use your car.
Every year I have been on CF, I explain over and over and over that you cannot leave lead acid batteries sit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
To relay clicking sound
