Climate Control (Need Help)
Old Nov 25, 2001 | 11:23 AM
EtidW's Avatar
EtidW
Default Climate Control (Need Help)
There are times when my climate control adjustments do not work. It is always the temperature adjustment down switch and as well the off switch. Seems the switches on the left side of the control. This will last for a time then all returns for awhile but eventually it starts to go bad again. Anyone out there had the same trouble?
Old Nov 25, 2001 | 12:11 PM
RichS's Avatar
RichS
Default Re: Climate Control (ETID)
I had a simular problem with my 95. I removed the controll head and took it apart. I then cleaned all the connections and button pads. reassembled making sure all conections were good. Then it worked great. No other problems with it.
Old Nov 25, 2001 | 06:44 PM
KYVette90's Avatar
KYVette90
I've got the same intermitent problem on my 90. Some times it comes on by itself and other times it won't go off or switch functions. It usually only happens when its wet outside or humid. I'll try taking it apart and cleaning it. Anybody else know any other solutions?
Old Nov 25, 2001 | 09:08 PM
Dualnic's Avatar
Dualnic
My 94 does the same thing to the "T".....but it is very rare when it does happen.....but on mine...when it does....i just turn off the car and restart and the Climate Control...is back to normal....but i was also thinking of taking it apart and cleaning the contacts, just to see if that would help.
Old Nov 26, 2001 | 12:47 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Climate Control (RichS)
Mine does it too. Thanks for the advice. :cheers:
To Climate Control (Need Help)
