Steering Rack Recommendation???
Old Nov 25, 2001 | 03:11 PM
Rich B.'s Avatar
Rich B.
Default Steering Rack Recommendation???
My rack has been leaking a bunch; flushing reveals metal particles. I'll R&R the rack and pump.
I priced rebuilt racks at = Autozone - $137; NAPA - $203; ZIP - $259; TLD - $222. All exchange.
Only ZIP has AC Delco rebuilt racks. The others are all generic/no-brandname rebuilders. All special order. NAPA/Autozone are lifetime warranty.
My question, since Autozone is cheapest, is there anyone with recommendations for any of the others? Horror stories?
Thanks for your time! :D
Old Nov 25, 2001 | 04:43 PM
ZAP's Avatar
ZAP
Default Re: Steering Rack Recommendation??? (Rich B.)
I would look localy for a rebuilder. I found a quik ratio for my 86 that way. cost was $130-140 range about 2 years ago.
:cheers:
Old Nov 25, 2001 | 07:03 PM
J.H.'s Avatar
J.H.
I replaced the rack on my 85 in May of 2000 and so far all is well. I bought the rack from AutoZone. The only difference I see is that the turning distance is a bit wider than on the original unit. The car does not turn ar short as it did before. However, I replaced the rack on my Dodge Caravan back in 1999 with an AutoZone unit and now there is some play in the right inner tie rod. The Vette rack is fine, the Van rack has a little problem. It does have a lifetime warranty, but I don't feel like the hassle of removing it until I absolutely have to if it ever comes to that.
Old Nov 26, 2001 | 11:13 AM
GRX's Avatar
GRX
I am coming up on this repair too, and I refuse to buy from Autozone. I will probably go with the GM Delco item from ZIP. :smash:
To Steering Rack Recommendation???
