freeze plugs
Old Dec 19, 2007 | 04:46 PM
90SteelBlueCoupe's Avatar
90SteelBlueCoupe
Default freeze plugs
do they just screw in like a bolt?
Old Dec 19, 2007 | 04:52 PM
Muffin's Avatar
Muffin
No, press in.
Old Dec 19, 2007 | 07:59 PM
IRAraid's Avatar
IRAraid
Default Freeze plugs
Get a 1" (or so) wooden dowel rod (centered on the freeze plug) and tap the freeze plug in gently with a hammer. After it starts, work around the edge with the hammer directly on the freeze plug until the plug is flush with the block.
We always carried several plugs, a dowel and a hammer on the boat; especially in salt water.
Good luck
Old Dec 19, 2007 | 09:38 PM
evmlarry's Avatar
evmlarry
Are you referring to the big round brass freeze plugs or the oil galley plugs? Oil Galley plugs screw in.
Old Dec 20, 2007 | 12:36 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
emergency freeze plugs have a bolt and nut, and you can tighten the nut in the center till you get to fix it right.
Old Dec 20, 2007 | 08:08 AM
runner140*'s Avatar
runner140*
Good luck
To freeze plugs
