Is this a problem with TPI plenums?
Old Dec 20, 2007 | 01:09 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Default Is this a problem with TPI plenums?
After looking at the TPI shootout recently linked, I noted no large-tube setup produced near the power of a short-runner setup. However, the superram got pretty-darn close with a mid-length setup.
The article also said it was surprising that the semi-siamesed ASMs didn't do better at high rpms. (They were hooked to a standard, ported plenum).
Now I'm wondering if the opposing tubes (esp in the middle) affect flow of the tubes on the opposite sides. IOW, would the force of air being drawn to one side of the plenum lower the speed of the pulses trying to go the other way?
I wonder if a "longitudal" partition was ever considered to separate the plenum in two air chambers -- each side fed by one TB opening.
gp
Old Dec 20, 2007 | 01:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
here we go....
Old Dec 20, 2007 | 01:16 AM
SHINOBI-X's Avatar
SHINOBI-X
here we go....
Hi Ron
Old Dec 20, 2007 | 09:26 AM
dclafleur's Avatar
dclafleur
Some people watch soap operas during the day, I watch GreggPenn threads.
Old Dec 20, 2007 | 10:48 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Some people must be really bored!
Old Dec 20, 2007 | 10:51 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
No. Because the opposing tubes are staggered from each other. The pressure distribution would actually be fairly equal. They will have some effect on the runner they're paired with though.
Think of the plenum as a long rectangular strip of grass with sprinklers. If the sprinklers are spaced out along both sides, staggering them gives more even watering. The circular pattern of the water is analogous to the low pressure region caused by that cylinder's intake cycle.
Now let's get back to that TQ vs HP thread.
Old Dec 20, 2007 | 11:14 AM
rick lambert's Avatar
rick lambert
Dang it....I really enjoy your threads Gregg.......
Old Dec 20, 2007 | 01:25 PM
GREGGPENN's Avatar
GREGGPENN
Hey, it's fun to have a stray thought and throw it to the wolves. I like watching them tear at the raw meat in a frenzy.
Picking on wings and kits gets more boring.....
gp
Old Dec 20, 2007 | 01:34 PM
KeyWestJack's Avatar
KeyWestJack
gp
Well if all else fails segue into 190 vs. 160 stats or Royal Purple vs. Mobil One.
Old Dec 20, 2007 | 02:19 PM
Aurora40's Avatar
Aurora40
This stuff makes me glad I bought a ZR-1. There isn't much to think about in terms of upgrades. What intake manifold to use? Well, there's only stock. What heads? Stock. What cams? Stock. And now there is only one header maker as well.
Old Dec 20, 2007 | 02:49 PM
KeyWestJack
some people are so smug.
Old Dec 20, 2007 | 03:00 PM
88BlackZ-51's Avatar
88BlackZ-51
368,385,415, and the list goes on.
I hear what your saying however.
Old Dec 20, 2007 | 03:38 PM
Aurora40's Avatar
Aurora40
Yeah, my wallet rules out those choices, so it's still easy
Old Dec 20, 2007 | 03:49 PM
GREGGPENN's Avatar
GREGGPENN
This stuff makes me glad I bought a ZR-1. There isn't much to think about in terms of upgrades....
That just gives you more time to figure out which kind of wax to use...
Old Dec 20, 2007 | 03:59 PM
Aurora40's Avatar
Aurora40
well played!
Old Dec 20, 2007 | 05:35 PM
88BlackZ-51
I guess you will have to settle with less then 400hp. Thats not so bad.
Take it easy! Too bad that there is a limit with the ZR1, then you have to spend the big bucks.
BTW, The stock "TPI" sucks for making power. Pure and Simple!!
Old Dec 20, 2007 | 07:42 PM
GREGGPENN's Avatar
GREGGPENN
Uhhhh.... all intakes "suck".... DUH!
To Is this a problem with TPI plenums?
Old Dec 21, 2007 | 01:29 PM
88BlackZ-51
Did I say that peanut?
Old Dec 21, 2007 | 02:29 PM
ZumZum's Avatar
ZumZum
My friend with the 4-71 huffer will tell his intake blows.
Old Dec 22, 2007 | 02:48 AM
staugur's Avatar
staugur
Hate to ruin your day but you should see what Lingenfelter and Mercury marine did to those babies.Lotus did some wild stuff as well.
They are much like the jaguar V-12's.Over engineered and underpowered.A 1.6 litre Coventry Climax twin overhead cam motor puts out more oomph.I believe originally they were intended as a marine engine as mercruiser traditionally used GM blocks and sticking them in a car was an afterthought.
