Removing Heater + Fan assembly
Old Dec 22, 2007 | 04:11 AM
Light84vette's Avatar
Light84vette
Default Removing Heater + Fan assembly
Wanting to loose some weight and make it easier to get to the passanger header bolts. And a future down pipe for a turbo
How should I reroute the coolant from the waterpump and one out the intake that goes to the heater. Any pictures of the whole unit removed? I seen a carbed Grand sport replica with this unit removed but I cant find those pictures, thanks
Old Dec 23, 2007 | 03:30 AM
Light84vette
TTT, has anyone ever done this before?
Old Dec 23, 2007 | 04:06 AM
86GoldProject's Avatar
86GoldProject
to get rid of the heater hoses just remove the fittings from the intake manifold and from the water pump and replace them with pipe plugs. I don't have any pics of the heater box removed but you should be able to do it, don't know if anyone makes a heater delete for our cars or not, but if you're getting rid of it you could just take the old heater box and trace it and make a block off plate out of something like a thin piece of sheet metal and paint it black to make it blend in.
Old Dec 23, 2007 | 04:09 AM
86GoldProject
I'm assuming you are removing the A/C evaporator too if you haven't already.. that should really clean up that side of the engine bay, if you make the block off plate it would be a nice place to mount an MSD box..
To Removing Heater + Fan assembly
