$3,000 for LT1 mods........HELP!!!!!
Old Dec 25, 2007 | 10:49 PM
96_vette's Avatar
96_vette
Default $3,000 for LT1 mods........HELP!!!!!
I have $3,000 from x-mas money. I want to use it on my 96 LT1. The car is a daily driver, so i dont want track mods, just some more power for the stop light grand prix. Its bone stock minus a open air filter lid and K&N filter. I want to free up some horses. Im thinking about a whole new exhuast from headers back. I dont really want to install a new cam or heads. Anyone have some suggestions on how 3 grand could be spent wisely?
Old Dec 25, 2007 | 11:09 PM
96 lt-4's Avatar
96 lt-4
you guys want to adopt somebody??$3k for xmas=WOW
i am assuming it's an auto.
catback exhaust
1.6 roller rockers
stall converter & shift kit
maybe gears
dyno tune
Old Dec 25, 2007 | 11:42 PM
96_vette's Avatar
96_vette
Yeah its a auto, thanks for your advice. Adopt? Only if you have a
ZR-1!!! thanks........
catback exhaust
1.6 roller rockers
maybe gears
dyno tune
Old Dec 25, 2007 | 11:49 PM
SHINOBI-X's Avatar
SHINOBI-X
catback exhaust
1.6 roller rockers
maybe gears
dyno tune
Took the words right out of my mouth.
Old Dec 26, 2007 | 12:18 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
If you want to make a difference via seat of the pants do 3.75 gears, 2500-2800 stall converter and Long tube headers. You will be smiling every day after that, and buying new tires soon!!!
Old Dec 26, 2007 | 05:36 AM
C4Rich's Avatar
C4Rich
Cruising
how do the 3.75 gears effect mileage and top speed?
Old Dec 26, 2007 | 06:46 AM
96 lt-4's Avatar
96 lt-4
i suspect you would lose 3-5mpg and some top speed.not that you can safely run anywhere near top speed on the highway.
3.07 would be a good gear(you may already have it),or look for a 3.36(right?)out of a dana 36.
Old Dec 26, 2007 | 07:10 AM
aboatguy's Avatar
aboatguy
IMHO The best bang for the performance buck on an LT1 is gears.
I'd love my 3.45s.
If your going to drop in a cam a converter would be a good mod too.
I love my LT headers however, the gears provided a better $$$$$ to performance ratio.
If your budget was double what you have right now
I'd suggest,
Gears/ or D44 swap
2800 or higher stall
Ported heads
Cam
LT headers
EWP
Old Dec 26, 2007 | 09:10 AM
IcemanZ06's Avatar
IcemanZ06
I agree with gears, stall convertor, and longtube headers. The stock exhaust is good for up to about 400hp and it should sound pretty good with the headers. Provided you can do some of teh work yourself you might even be able to squeeze in 1.6RR or a tune.
Old Dec 26, 2007 | 09:25 AM
rickneworleansla's Avatar
rickneworleansla
I'm saving up for this but I currently have most of the supporting mods.
Head/cam package will pull from 2,300 to 6,500 RPM and should make *400 - 420 RWHP with 30/36 lb. injectors, 58 MM T.B., 1 ¾ LT’s, no cats, good tuning, etc. This will have
an idle similar to the CC306 cam but will make more HP & TQ across the board. The REAL
difference is the amount TQ this cam makes in the 2,500 – 3,500 RPM range compared to
the cc306.
The LT1 LE2 heads consist of:
Ferrea 200/1.56 Valves
CM Retainers & 10° Locks
Comp Bee Hive Springs
205 CC Intake porting
Milling. Cleaning, Assembly
Flow about 275/190
Ready to bolt on
LE2 Head/Cam Package - $1,750 plus shipping. $1,400 for Heads only.
Old Dec 26, 2007 | 09:31 AM
96_vette's Avatar
96_vette
So the stock exhaust has little restriction and back pressure? If I install headers, and keep the rest of the exhaust stock, wont the stock components have more restriction?
Old Dec 26, 2007 | 10:36 AM
MR NICE's Avatar
MR NICE
If you do your own work,nitrous ,exhaust,rockers,converter,and gears should be possible. The only other way to make more power would be supercharger/turbo,heads or cam.
Old Dec 26, 2007 | 11:48 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
There will be a big difference on what you can do depending on weather you are doing the work yourself or not.
Old Dec 26, 2007 | 11:59 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
It's a shame you don't want to do cam/heads. That's the main upgrade for your car. Hotcam kit and port your stock heads. You can do that for about $3K even if you don't do any work yourself. Check it out!
Old Dec 26, 2007 | 12:07 PM
rickneworleansla
Sorry, didn't see the part about no heads and cam. Just curious, why not?
Old Dec 26, 2007 | 01:09 PM
Kevin Woods's Avatar
Kevin Woods
catback exhaust
1.6 roller rockers
maybe gears
dyno tune
Definately gears.......
Add headers to the cat-back......
And valve springs when you do the roller rockers !
KW
Old Dec 26, 2007 | 01:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
Noticed a 1-2 mpg loss tops going to 4.09 gears, totally worth it.
Id recommend the gears/converter/LTs first.
If youre still hungry port the heads, intake, and a cam. It will stand up and run real hard with those mods.
To $3,000 for LT1 mods........HELP!!!!!
Old Dec 26, 2007 | 01:26 PM
dan0617's Avatar
dan0617
Since it is a daily driver I'd consider shopping for a used supercharger. Or if you don't need the power all the time, nitrous. I have a zex nitrous kit and I love it. Stay at 100 to 125 hp shot and you shouldn't have any problems. You will have enough money left over for headers, 1.6 roller rockers and maybe even a converter. I honestly would stay at a 2000 (or 2200 max) rpm stall speed converter since it is a daily driver. 2800 stall is great but your gas mileage will go down the toilet. I have a 2800 and my gas mileage went down the toilet. If you do gears, I'd stay at 3.45's. 3.73's or 4.10's are great but again gas mileage down the toilet and cruising rpm's are much higher than stock. So for me, I'd do it in this order:
Zex 125 shot
Converter
1.6 roller rockers
Headers (I wouldn't eliminate cats since it is a daily driver)
Gears
I don't know your mechanical abilities, but I'm sure you can install the nitrous kit and the rockers yourself. The converter and gears should be done by a tranny shop or professional if you don't have a lift and major mechanical abilities. Headers are a pain and I would suggest a garage do them, but if you can get the car up high enough and you are patient with exhaust work (I AM NOT!) then you could do them yourself.
Old Dec 26, 2007 | 01:58 PM
96_vette's Avatar
96_vette
Thanks for your advice! I wont replace the converter. But headers and complete exhuast system are a GO! I probally wont go with a supercharger. New heads and cam, maybe. Yes I am a mechanic, 15 years now. Just dont have the time anymore. I like to discuss my options with other modders first! Thanks.........
Zex 125 shot
Converter
1.6 roller rockers
Gears
Old Dec 26, 2007 | 02:38 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
I would suggest that you check out the PNW section. You are with a r3easonable drive time of Tom Wong's shop in Portland. He is the top tuner on the PNW and will give you straight up advice about what you can do with your car.
PS if you're putting on new LT headers there is no need to waste $$ on a new cat back system.
