Fog Lights
Old Dec 26, 2007 | 09:51 AM
Mitch92's Avatar
Mitch92
Default Fog Lights
anyone know how to change the fog light bulb my 92 cant see how to get the bulb out to change it.
Old Dec 26, 2007 | 10:27 AM
rickneworleansla's Avatar
rickneworleansla
There is a small flap for each fog light that flips down and forward. They are located under the front bumper. There should be one bolt holding each flap shut.
Old Dec 26, 2007 | 10:29 AM
Mitch92's Avatar
Mitch92
so it is under the front bumper not under the hood..so just look under the front bumper and I should see the flap
Old Dec 26, 2007 | 10:30 AM
Steel Blue 91's Avatar
Steel Blue 91
If you look under the bumper cover directly under the fog light, you'll see a swing down door on each side held up by a 7mm (I believe) screw. Swing the door down, twist the connector to the left and pull down.
Old Dec 26, 2007 | 10:32 AM
rickneworleansla
That's how it was on my 95. Be carefull not to twist the lights too much when installing. I broke one of them the first time.
Old Dec 26, 2007 | 10:35 AM
Mitch92's Avatar
Mitch92
Ok cool....thanks guys I will check it out this eve,,,then I need to get my high beam working on the steering column and I am back in business
To Fog Lights
