Tire pressure?
Old Nov 26, 2001 | 10:24 PM
BBA's Avatar
BBA
Default Tire pressure?
Well, I went from 16" 255/50's to 17" 255/45's & 275/40's.
I noticed it rode pretty harsh with the new tires...smoother at speed, but I think I could tell the date on a dime if I ran over one.
I lowered my tire pressure from 42 PSI down to 36 PSI. Man what a difference.
It seems SOOOOOOOOO much smoother riding. Handling seems fine, it doesn't spin the tires as much now, and corners seem a little quieter.
Do you think I'm running too low a pressure? :chevy
Old Nov 26, 2001 | 10:39 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: Tire pressure? (BBA)
I run mine at 33 with no issues... may depend on the tire somewhat, but otherwise I'd say no, your fine.
Old Nov 26, 2001 | 11:54 PM
BBA's Avatar
BBA
Default Re: Tire pressure? (Springer's 95)
33 is ok for you...cool.
Have you noticed any wear patterns?
Old Nov 26, 2001 | 11:56 PM
AS84's Avatar
AS84
32 in mine currently. So far so good on tire wear. Its amazing what a few psi can do to the ride.
Old Nov 27, 2001 | 12:17 AM
R23HTC's Avatar
R23HTC
Default Re: Tire pressure? (AS84)
I run 36psi front and 34psi rear. I believe the recommend pressure is 32psi for both or 35psi for high speed driving or racing. I run mine for best tire wear. Ride isn't to bad. I think 42psi may be within the tires specs, but is way to much for a decent ride/wear.
Old Nov 27, 2001 | 01:10 AM
Hutch's Avatar
Hutch
If I recall, the factory recommendations are 32 psi front and back for normal driving and 35 psi front and back for extended high speed driving. I generally split the difference and keep mine around 34 front and rear.
IMHO, 42 psi is way too high and will cause premature tire wear and a harsh ride.
Old Nov 27, 2001 | 05:59 AM
93 ragtop's Avatar
93 ragtop
Default Re: Tire pressure? (gs633)
I run mine at 30. This is what is recomnended for the conv.
Old Nov 27, 2001 | 07:03 PM
jay17's Avatar
jay17
Default Re: Tire pressure? (Red 86 4+3)
I also run mine at 30.
Old Nov 27, 2001 | 08:39 PM
Scott LeMuke's Avatar
Scott LeMuke
I run my Firehawk SZ50's at 35 PSI, the pressure recommended by Chevy for high speed driving. (I rarely get above 106 MPH on the street)
The Firehawks are labled with a maximum inflation pressure of 44 PSI.
I found my tires gained at least 4-6 PSI after heating up on long drives.
Therefore, I did not want to inflate them to anything above 38 PSI, or they would heat up and the pressure would exceed the 44 PSI maximum inflation pressure. :)
To Tire pressure?
