HELP Ignition switch
Old Dec 28, 2007 | 09:55 AM
covette mama's Avatar
covette mama
2nd Gear
Default HELP Ignition switch
I need help finding out what part I am going to need. When I try to start my 92 it is like the key won't turn that final twist to start it. It is almost like the battery is dead but it isn't. I jiggled it and got it started but it needs to be fixed. Would I just need a ignition switch or could it be something else?
Old Dec 28, 2007 | 01:21 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Do you mean the key won't physically turn?
Or it turns all the way, but nothing happens with the starter?
Old Dec 28, 2007 | 04:34 PM
covette mama
2nd Gear
No it turns but it just doesn't turn the whole way, I have checked my starter, alternator and battery all are good. Think it might be the key, have my other set on the way here to try that, I am thinking it is the key or the ignition. It is like you are starting it and the battery is dead...it doesn't turn all the way.
Old Dec 28, 2007 | 04:51 PM
rick lambert's Avatar
rick lambert
you may have a bad tumbler. One thing alot of people do is put to many keys etc. on there key ring, and that takes out ignition switches pretty fast.
To HELP Ignition switch
