Maf maxed, WOT Lean-Out !!!
Old Dec 28, 2007 | 06:28 PM
Ratty Vette's Avatar
Ratty Vette
3rd Gear
Default Maf maxed, WOT Lean-Out !!!
I've got a 383 mini-ram, 245 deg 580 lift, 30lb inj, runing 6E w/guted maf that hits the 255 wall by 5k. O2 drops out by 5300, added fuel to PE, scaled back Maf vs RPM to not max till 6400 but still can't get enough fuel, rail press holds at 47psi. Comand fuel is like 10:1, time for some 42lb injectors or time for SD aka 730?
Old Dec 29, 2007 | 12:45 AM
tequilaboy's Avatar
tequilaboy
Sounds like the time for bigger injectors (or more fuel pressure) 63 psi should make those 30s flow like 36s.
I'd be tempted to try this first.
42s may be overkill for an N/A engine. I just installed some 42.5 lb. Lucas injectors, but unfortunately I tore an o-ring on the fuel rail, so its not up and running yet.
I hope I can get it to idle well with the 42.5s. I know some have had problems at idle with 42s and the inevitable low injector pulse widths.
I would also raise the max MAF vs. rpm table so that you max the MAF earlier rather than later and add all the extra fuel via PE after the MAF is maxed.
Reducing the max MAF vs. rpm table in a attempt to extend the rpm range of the MAF is only making things leaner than necessary requiring even more PE enrichment.
Old Dec 29, 2007 | 07:07 AM
Ratty Vette
3rd Gear
I know the 42's many be pushing it a tad, I was thinking about playing aorund with the pw adder around the idle, to handle the short pw
I did play with the maf max flow vs rpm and it did lean it out (scaled it back so it wouldn't see 255 till 6400) when I brought it in sooner I lost fuel control pig rich lower rpm with same lean out upper. I keep pushing the PE vs RPM up but couldn't keep the O2 from crashing out even though the conmand was like 10:1
Old Jan 19, 2008 | 03:56 PM
Russ K's Avatar
Russ K
Lower the injector flow rate table, then lower the maf table at the lower HZ. Try lowering the IFR by 10% at a time.
Russ Kemp
To Maf maxed, WOT Lean-Out !!!
