Horn help needed
Old Dec 29, 2007 | 01:43 AM
Y-ME's Avatar
Y-ME
Default Horn help needed
Have an 87 where both the horn blows constantly. I took apart the button and it they still blow, so it's not the contacts, any idea's?
Old Dec 29, 2007 | 05:41 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Try the Relay,
Old Dec 29, 2007 | 01:06 PM
Y-ME's Avatar
Y-ME
So the relay sits behind the info center with the alarm fuse?
Old Dec 29, 2007 | 06:17 PM
fijidan's Avatar
fijidan
i recently fixed the horn on my 84, turned out the short was in the steering column right behind the steering wheel... there is a peice of plastic separating the spring (which acts as a positive wire) and the hub (ground point) -- that plastic peice can rot and short out
to fix mine i wrapped the spring in electrical tape and made a new plastic peice and its worked ever since--
Good Luck with it,
Dan
To Horn help needed
