Moisture under the oil cap...
Old Dec 30, 2007 | 12:21 AM
rg951's Avatar
rg951
Default Moisture under the oil cap...
Does moisture under the oil cap always mean head or head gasket issues?
I just had the heads professionally rebuilt, checked, & new Head Gasket installed. I brought it in because there was signs of a blown gasket (white smoke from exhaust, white milky substance under oil cap, & coolant kept going down). When they took it apart....it was bad.
I've had it back for two weeks & it runs great. The temp runs normal, no white smoke from the tailpipe, the coolant levels don't move & is always full.
Today I removed the oil cap cover when I just got home. There was like condensation on the under side but it was like a dry grayish look. Didn't look like white so much. I put the cap back on and went about my business. I went back to check the car again about 20 minutes later because I forgot to check the oil levels (which looked good....no white substance). Checked the oil cap again & just seems like condensation on the bottom of it.
Any suggestions...or is this pretty normal?
Old Dec 30, 2007 | 02:50 AM
johnnyevans's Avatar
johnnyevans
It could be some seepage from the head bolts. Doesn't happen often, but it does. It's caused by the threaded bolt holes are open to the water jacket.
I would pull the bolts loose, one at a time, and use a sealant, and retorque.
Old Dec 30, 2007 | 03:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
I woudlnt sweat a little condensation, especially if the car didnt run too long or stay warm for any length of time.
Old Dec 30, 2007 | 06:03 AM
Sliding's Avatar
Sliding
I noticed same thing occasionally even in PCV system lines.
It's just condensation. But if it looks like milkshake that could be a problem.
Old Dec 30, 2007 | 06:07 AM
RRT vette's Avatar
RRT vette
Just an eye on it and the oil. Doesn't sound like a big deal unless it progresses.
Old Dec 30, 2007 | 07:32 AM
MR NICE's Avatar
MR NICE
what temp t/stat?
Old Dec 30, 2007 | 08:56 AM
Iroc57's Avatar
Iroc57
It is probably a result of some short errands.
Old Dec 30, 2007 | 10:59 AM
rg951's Avatar
rg951
Fortunately, I live 4-5 miles from work….unfortunately, the car never gets warm enough or even above 173 before I get home. It has a 180 temp stat installed so I barely get any heat (warm air) by the time I get home.
I did some reading here & there and some people are saying it’s normal because the car is not getting hot enough (or running long enough) to burn any normal condensation inside the engine.
Thinking about it....I doubt the car is even running longer than 10 minutes.
Old Dec 30, 2007 | 11:09 AM
c4cruiser's Avatar
c4cruiser
Given the short trips, you should try to drivie the car for about an hour at freeway speeds. Let everything get to operating temp especially the oil temp. This should get the crankcase hot enough to remove excess moisture. Chances are what you are seeing is some remaining condensation from the earlier head gasket failure.
Check under the cap again after the car cools completely (like the next morning) and see if the stuff is still there. You can always drive another one hour stint to further help dry out any remaining condensation.
Not letting the fluids get to operating temp will keep condensation in the crankcase and eventually build up sludge. You will also get moisture in the exhaust system which will cause corrosion.
Old Dec 30, 2007 | 11:40 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yep, those conditions are about the worst you can put your car through.
The condensation is never being evaporated off.
I am in the same situation as you, and at least once a week I will actually take a longer way home, so I can get the car up to operating temps.
And keep in mind that the oil temp will take longer to get up than the water temp. A good 15-20 mile drive before the oil temp gets up in the winter.
Old Dec 30, 2007 | 11:56 AM
rg951's Avatar
rg951
Yeah....I think that will be a good idea. The short trips are nice on saving gas, tires, time, etc....
but the short trips can do harm.
Old Dec 30, 2007 | 01:50 PM
RollaMo-LT4
Yep, gas is still cheaper than an engine replacement or rebuild due to premature wear.
The same can be said for the guys that store their cars through the winter. Some of them want to go out and start them and run them for a bit once or twice a month.
If you only storing the car through the winter months, unless you can drive it for a good 15-20 miles your better off not even starting it. Putting the away for 4 or 5 months during the winter is not long term storage.
Old Dec 31, 2007 | 04:13 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Change the oil and filter again and put some good oil in it ,not that mobil one crap.
Try the Vavaloine racing oil for a 2k oil change and that should clear it up.If they used the wrong sealent on the head bolts you have a problem.
I use the B2 formula from MR gasket on the Ltx motor head bolts.
You can also get that milky look in the valve covers if the intake bolts need retorking (leaking waster).
When your engine was new GM installed some sealent crap in the radiator to seal the bolts from the factory,I for get waht it is.
To Moisture under the oil cap...
