Which wire is which?
Old Dec 31, 2007 | 05:38 AM
BTU83's Avatar
BTU83
Default Which wire is which?
My turning signal on my 1984 Corvette is acting funny. My green arrow in the car for a right turn will stay illuminated when the headlights are up, but goes away when they are down. My right blinker works normally with the headlights up or down, but will not shine at all when in the daytime running lights mode. I have throughly explored my options, and I've concluded that there must be some corrosion, disconnection, or wire destruction somewhere along the path for this daytime running light. I don't have a service manual which is making this harder. Does anyone know which of the 3 wires going into right blinker sockets belong to the daytime running lights? And perhaps a good place to look for an interference along the wire?
Side note. Changing one of the fog lights from under the hood is proving impossible because the socket cannot be pulled out and the metal cylinder is loose. Any advice?
Old Dec 31, 2007 | 12:55 PM
Keystring's Avatar
Keystring
You need to get the FSM with the electical supplement.
Diagnosing electrical problems without a diagram is a nightmare.
Even with a manual and diagram it can be pretty challenging sorting it all out.
Old Dec 31, 2007 | 01:09 PM
C5rider's Avatar
C5rider
Sounds like one of the pins on the connector behind the dash has finally sooted up enough that it isn't making a good ground anymore. Just a hunch. That'll make your turn signal indicator do funny things.
Old Dec 31, 2007 | 03:38 PM
BTU83's Avatar
BTU83
I checked under the steering column, everything looked good and connected!
Old Dec 31, 2007 | 03:56 PM
qws's Avatar
qws
84 wiring diagram
http://misterbill.homeip.net/vette/wiring/
Old Dec 31, 2007 | 05:12 PM
Yellow2015's Avatar
Yellow2015
Check the grounds.
The fog lights aren't that hard but they are long so be careful pulling them out. Drivers fog............use left hand.............passengers fog......use right.
Old Dec 31, 2007 | 06:42 PM
BTU83's Avatar
BTU83
The fog light simply won't come out. The long metal cylinder just rattles and moves around and wont slide out. Thanks for the wiring diagram. Does anyone have a link, map, or picture to the fuse box as well? I have no manuals for this car yet. Thanks!
To Which wire is which?
