Ok, I was putting an engine block on my stand and one of the bolts snapped off while I was tightening it. It was weird, because It wasnt tightened all the way and the rest of them were. The bolts were supposed to be Grade 8....What now? Thanks, Zak.
If it broke because you crossthreaded it, you have problems. If it simply broke (and I have never, ever seen a grade 8 simply snap),
drill the center out of it and twist it out with an easy out.
If it is cross threaded. Take it to the machine shop. They will drill it out carefully, and install a heli-coil thread insert to restore the threads.
I agree with the Batmobile as I have never experienced a grade 8 breaking during the insertion process. Did you attempt to put a metric thread in an English tapped hole or vice versa?
This is an interesting subject. A few things come to mind with my experience with broken bolts.
Was the bolt hard to start and did it continue to be hard to turn til it broke? If so, then it could be crossthreaded or the wrong thread was used which in either case no easy out is going to remove. It will have to be drilled out.
Was the bolt easy to start and did it continue to be easy to turn until it stopped and then broke. If so, then it is usually due to the bolt bottoming out or too much torque was exterted. This type of break my allow the use of an easy out of some type because once the bolt broke then the pressure on the threads was released allowing the broken piece to be removed by drilling and using an easy out or a left handed bit. If it was a grade 8 then you'll need a harder drill bit. This situation also lends itself to simply using a pick and backing out the screw tediously until you can get a grip on it. Highly unlikely to do but I've been able to do it on occasion (exhaust manifold bolts).
Depending on the type of fastener, the force needed to start it in the hole, the force to turn it until it broke and the torque exerted before the bolt broke will determine what the next course of action will be.
Art
I broke a grade 8 on a splade main cap.The machine shop did not drill the threads all the way down and when removing it the end of the bolt snapped.Use the reverse drill bit you can get for drill presses and use the smallest bit to start with that you can.
Hello,
There isn't anything EASY about an easy-out! If there is any part of the bolt hanging-out, weld a nut on to it and use tools to remove it.
If it is cross-threaded, drill it out and install a heli-coil. If you are not equipped to do this, get a shop to do this. By the way, NO Shop is going to garuntee this work. They are trying to patch your 'screw-up'.
If there's any of the bolt left sticking out grab it with some vise grips. If it's flush center punch it and drill it and use an EZ-out.
Also you may consider filing two flat spots opposite each other and using an open end wrench to get it out. (assuming of course that there's enough of it sticking out to do so.)
