Deleting the ABS block?
Old Jan 1, 2008 | 02:21 PM
Nitrofish86's Avatar
Nitrofish86
Cruising
Default Deleting the ABS block?
Has anyone completely did away with the ABS block behind the driver's seat? Is it a simple bypass or would I need to re-run the whole brake system lines? I have an 86 coupe. I have no use for it with what I'm doing and the weight savings would be an added bonus.
Old Jan 1, 2008 | 09:05 PM
tpi 421 vette's Avatar
tpi 421 vette
I completely removed my abs. It just takes some time to cut and reflare the lines. Make sure you have a quality double flare reflaring tool. You will have to "T" the 2 inlet lines into the 4 outlet lines. The brakes work fine afterwards. My car stops fine after running 134 mph thru the quarter.
Old Jan 1, 2008 | 09:39 PM
Nitrofish86
Cruising
Right on, thanks man-Charlie
To Deleting the ABS block?
