Manual brake conversion
Old Jan 1, 2008 | 02:25 PM
Nitrofish86's Avatar
Nitrofish86
Cruising
Default Manual brake conversion
Anyone have any details on a manual brake conversion. Will the master cylinder bolt straight to where the booster was?
Old Jan 1, 2008 | 04:16 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I just unplugged the abs system behind the drivers side seat and installed a vaccum pump on the pass side above the window washers and was done with it.
Old Jan 1, 2008 | 04:35 PM
Nitrofish86
Cruising
So you left the ABS block and Brake booster installed?
Old Jan 2, 2008 | 12:38 AM
REDC4CORVETTE
Yep!
Old Jan 2, 2008 | 10:28 AM
Deakins's Avatar
Deakins
Or if you are like me and almost wrecked your car when the vacuum pump stopped running you can run a hydro boost system that uses the power steering pump to add assist. If the engine is shut down you won't have assist for long but at least you know you will have it when the engine is running.
Old Jan 2, 2008 | 11:05 AM
redrose's Avatar
redrose
with manual brakes you'll need a master cyl with smaller bore than a power brake master...try a 68 vette/manual brake m/c, abt $65 new/$30 rebuilt at most discount auto parts (you'll need to fab a mounting adapter and push-rod).
Old Jan 2, 2008 | 06:12 PM
DVNCI's Avatar
DVNCI
There are some on here who can talk much more intelligently about this than me BUT my car is currently at the chassis shop for a solid rear install and we will be doing this as well - so I'll have a solution in the next month or so I can post to see how my builder (who is A+ guy) solves it.
From what I have read you have to change the geometry a little to get a little extra leverage since you are no longer running the power assist. I'm gonna let him pick a master cylinder but I think he usually runs a Lamb, don't know what size yet.
Old Jan 4, 2008 | 06:06 PM
Nitrofish86
Cruising
Sounds good, btw I'm following your build-up. Looks very well thought out and great work being done.
Old Jan 4, 2008 | 11:55 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Neverlift did my conversion
They can supply you with all the correct parts.
Old Jan 5, 2008 | 12:01 AM
Nitrofish86
Cruising
Thanks for the info guys
To Manual brake conversion
