will this prom work?
Old Jan 1, 2008 | 06:03 PM
geogolf's Avatar
geogolf
Default will this prom work?
hey guys does any one know if a prom from a 91 camaro ecu#1227730 will work in a 1990 corvette ecu#1227727, reason i ask i have one from a camaro that has a pcmforless prom in it, and was going to try it in my ecu thanks in advance for any help geo.
Old Jan 2, 2008 | 09:29 AM
mseven's Avatar
mseven
727 and 730 should be the same (including datastrems, bins etc.).
I don't see a problem with the swap but I would still read the bin (prom from the f body) for trans lock points etc. if you plan on using it "as is". What are you intending ? just trying a stock prom or an ecm swap?
Old Jan 2, 2008 | 12:39 PM
YoMilkMan's Avatar
YoMilkMan
it will work,maybe not good.You have aluminum heads on a vette and not a F-body. your timing will be differnt in each chip is the main concern...
To will this prom work?
