What is this electrical part??
Old Jan 2, 2008 | 10:23 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default What is this electrical part??
Does anyone know what this part is?
GM part # 1407-3971
Old Jan 2, 2008 | 05:08 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
not sure think it is for the vats ,should be located in the center of dash to the right.
Old Jan 3, 2008 | 12:17 AM
pmihaltian's Avatar
pmihaltian
Slingshot
I came out from under the VATS unit up under the passenger side courtesy light area. I originally thought that it was the Courtesy Light Delay Timer, but it is not. I don't think its the VATS system because that system still works. Could be hatch open relay or safety belt alert system or consol lights. I just don't know, but still need help identifying it.
Old Jan 3, 2008 | 12:25 AM
REDC4CORVETTE
I know it is not for the hatch release,I removed that black box from my 86 coupe and the hatch still works.
I will have to check my book tomorrow when I get to the shop.
Old Jan 3, 2008 | 12:48 AM
86PACER's Avatar
86PACER
Look under the dash and search for a loose 4 wire connector with colors black, green, gray, and pink/black.
If you find one and it snaps into it, that thing is the "Low Coolant Module". Which is located in the area you described this came from. That part number brings up nothing.
With the low coolant module unplugged, your low coolant light will never come on even if everything else is in tact, and there really is low coolant in the radiator or it's empty. That's one way you'll know. It looks very similar to the low coolant module on my car. Even that tan spade plug under it looks the same. Only mine was not black, it was transparent.
Old Jan 3, 2008 | 08:19 AM
rich653's Avatar
rich653
Yes looks like the pn is way discontinued unless someone has the original parts book from 86, I was thinking it may be the headlight /ignition warning chime, I have an extra vats relay and it's not that. Now I'm curious, I know I seen it when I was working under my dash.
Old Jan 3, 2008 | 08:54 AM
Can86Z51's Avatar
Can86Z51
I have an 86/early 87 parts book, and that part # is not listed in there?!
Old Jan 3, 2008 | 09:52 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Stumped !
Old Jan 3, 2008 | 09:57 AM
pmihaltian's Avatar
pmihaltian
Slingshot
I'll check it out and let you know. Thanks much for all your valuable input.
Old Jan 3, 2008 | 09:58 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Look up the Low Coolant Module (relay) and see if there is a part # listed. Thanks.
Old Jan 3, 2008 | 10:24 AM
Can86Z51's Avatar
Can86Z51
OK - may be something odd here! The original post/picture in this thread clearly showed a module/relay(?) of #14073971. Now, my 86/87 GM parts book shows two different #'s for the 'Low Coolant Indicator Module' - #22533547(for 87), and #14078971(for the 86)! Could there be some sort of error/misprint on the 86 Module # listed for the 86?! Just a thought? Cheers.
Old Jan 3, 2008 | 11:50 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Oh, I think that you have it ! The module is marked 1407-3971, but the 3 could be an 8. At any rate I am going to check it out and see if 1407-8971 is still available. Thank you very much
Old Jan 3, 2008 | 06:54 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I checked the wiring out and, yes, the 4 wire connector has black, green, gray, and pink/black wires. I think that we have finally identified this rascal. Thanks to all and to 86Pacer for the final ID.
Old Jan 3, 2008 | 06:55 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks, Don. I really appreciate your help here.
Old Jan 10, 2008 | 08:05 AM
gking's Avatar
gking
Default Module
I have PN 22533547 in my GM service manual which identifies the low coolant module and points to that area to find it.
I am searching for an available one.
Good luck
Old Jan 10, 2008 | 10:39 AM
gking's Avatar
gking
Default Low Coolant Module
I found a low coolant module on www.buyoemparts.com under part number 14078971 that is supposed to work on my 89.
Old Jan 10, 2008 | 01:03 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Can you give us the exact URL (web address)?
To What is this electrical part??
