RPO codes
Old Nov 27, 2001 | 05:16 PM
Nathan Plemons's Avatar
Nathan Plemons
Default RPO codes
I was just looking at my list of RPO codes again. I have most of them identified but not all. I thought I would post it here and let you guys go over them.
Filling in the blanks would be nice, letting me know if any of them are wrong would also be nice.
AC1 - 6-way power passengers seat
AC3 - 6-way power drivers seat
AJ3 - Driver inflatable restraint system
AQ9 - Leather sport seats
BGR - Plant Code, Bowling Green, KY, CPC
CF7 - Roof, Sun, Removable, Non-Transparent
C60 - HVAC System, Air Conditioner, Front Manual Controls
DL8 - Mirror, Outside, LH and RH, Remote Control, Electric, Heated
D3X - Gear Driven Speedometer(25513049)
D8I - Vehicle speed sensor
E57
E92
FE1 - Base suspension package
FX3 - Selective ride handling
GM3 - 3.45 axle ratio
G87 - 8.5 inch ring gear
IL3 - Trim, Interior Design (L3) (Base with AQ9)
JL9 - Antilock Front & Rear Disc Brakes
KWZ
LT1 - 5.7L Generation II V-8 Engine (VIN P)
ML9 - ZF6 speed transmission, 90 um, 2.66ist, o/d
MN6 - 6 speed manual transmission
NA5 - Federal emissions system, tier 0
NK4 - Steering Wheel, Sport Leather
QA1 - Wheel, 17x9.5", Aluminum, Styled
R8T - Control Sales Item No. 69 *Processing Option*
R92
UX0 - Speaker System, 6, Dual Floor Sill, Dual Extended Range Sail Panel
U1F - Delco Bose CD and Cassette
U52 - Instrument Cluster, Electronic
U75 - Power Antenna
V73 - Vehicle Statement, U.S./Canada
XAU - Tire, Front, 275/40ZR17/N BL R/PE ST TL HW4
YAU - Tire, Rear, 275/40ZR17/N BL R/PE ST TL HW4
1AZ - Order Modification, Orders Sold *Processing Option*
1SA - Package Option 01 *Merchandising Option* Preferred Equipment Group
45U - Primary Color, Exterior, Medium Green Metallic
64I - Interior Trim, Light Beige
643 - Trim Combination, Leather, Light Beige
649
Old Nov 27, 2001 | 09:18 PM
OcalaGuy's Avatar
OcalaGuy
Default Re: RPO codes (Nathan Plemons)
649 Seat Belt color light beige
That's the only one I could find. Go back and recheck your other numbers and make sure of the ones you don't yet have the info on.
