84 Headlight Issues
Old Jan 3, 2008 | 03:37 PM
euphonium_john's Avatar
euphonium_john
8th Gear
Default 84 Headlight Issues
I'm trying to stop the beast from winking.
Had some feedback from the uk and many helpful links as to how to stop the headlight from not working.
Trouble is all the links are for motors which aren't like mine.
Does anyone have any experience of sorting a headlight motor from an '84.
I think I need to clean the contacts - coulod just do to know where they are.
Cheers Folks.
Old Jan 3, 2008 | 05:56 PM
qws's Avatar
qws
Go here
http://www.crossfire.homeip.net/
then go to the tech section and you will an article about headlight repair.
Old Jan 3, 2008 | 06:21 PM
Brimis's Avatar
Brimis
I just did the headlamp on my 84. You need to buy a gear set. The gears which are made of plastic wear out which causes the headlamp to "wink". Easy fix, the gears cost less then $25.00. Email if you need help.
Old Jan 4, 2008 | 04:43 AM
euphonium_john
8th Gear
Thanks,
The gears are fine - it's just now and again the motor doesn't spring into life.
I've read it's something to do with the contacts - but the insides of my motor isn't like any I've seen in bits yet.
Old Jan 4, 2008 | 03:42 PM
MrRenoman's Avatar
MrRenoman
Try this link...
http://automobiletest.com/service/19...ghts/index.htm
click on the pics to enlarge them...
Art
To 84 Headlight Issues
