ZF 6 shift knob
Old Jan 3, 2008 | 06:37 PM
Leec4ce's Avatar
Leec4ce
Default ZF 6 shift ****
My 1996 LT4 ZF 6 received a new shift **** for Christmas
Tried to remove the old shift **** from my car tonight got as far as removing the pattern cover then it said "nope not going to come off" My guess is that the I need to find some kind of retaining pin or the piece of metal at the very top is a wedge that I have no clue how to remove.
any suggestions, on how to remove the shift **** would be appreciated.
Old Jan 3, 2008 | 06:47 PM
GGTOOLS's Avatar
GGTOOLS
Some guys says to grab the wedge with a pliers. However that didn't work for me. What I did was drill a small hole in the wedge, then screwed a self tapping screw in it and it came right out with a small slide hammer!
Old Jan 3, 2008 | 06:51 PM
90 Convertible's Avatar
90 Convertible
I use a screwdriver and pry it out. When I put it back together I only knock the wedge in just deep enough to clear the pattern cover to make it easier for the next removal.
Old Jan 3, 2008 | 07:05 PM
96GS#007's Avatar
96GS#007
Spray a little penetrating oil on the "wedge" and let it soak overnight. Grab it with vice grips and pull straight up to remove. The fallback is to use the screwdriver approach. Just be sure to protect the leather shift **** (assuming you want to reuse, keep, or sell it blemish free).
Don't bother reinstalling the wedge. Mine has been out for years without issue. You can tighten the **** down just fine.
Old Jan 3, 2008 | 07:15 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
http://forums.corvetteforum.com/show....php?t=1897283
Old Jan 3, 2008 | 11:25 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
This worked for me.
Old Jan 4, 2008 | 12:42 AM
F1Fan's Avatar
F1Fan
I'll second that.
Old Jan 4, 2008 | 12:47 AM
tcr75's Avatar
tcr75
when I went to change mine the wedge would not budge, even with penetrating oil. I ended cutting the ****, split in the middle from top to bottom. The wedge came right out, of coarse the **** bound for the trash!
Old Jan 4, 2008 | 06:57 AM
Leec4ce's Avatar
Leec4ce
Thanks for the info folks. Will let you know how it goes
Old Jan 4, 2008 | 11:53 AM
383_Proof's Avatar
383_Proof
Spray a little penetrating oil on the "wedge" and let it soak overnight. Grab it with vice grips and pull straight up to remove. .....
worked for me too but i somehow punched myself in the face when i pulled up!
Old Jan 4, 2008 | 12:33 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I'm sorry, buy thay right there is funny...
Old Jan 4, 2008 | 03:00 PM
383_Proof's Avatar
383_Proof
don't be sorry....i couldn't stop laughing when i did it. The wedge was in there so tight that when the wedge finally gave, my hands with the vise and wedge flew up full force right into my face...
it was my 1st time working on my C4. There should have been a warning label somewhere!
Old Jan 4, 2008 | 03:05 PM
Leec4ce's Avatar
Leec4ce
Thanks guys for the pointers. The oil did the trick wedge came right out. Special Thanks to 383_Proof kept my nose intac and did not punched myself in the face
Old Jan 4, 2008 | 04:01 PM
MGVette's Avatar
MGVette
Out of curiosity, what did you replace it with? I have considered switching mine.
Old Aug 7, 2008 | 04:50 PM
SGAL1's Avatar
SGAL1
Thanks to you guys...my t-punch came out with some small needle nose vise grips and some pretty hard tugging.
I grabbed the t-punch on the long ends...
then started tugging back and forth.
I didn't need the oil thankfully.
Once you get that part out....just un-screw the old **** and you are ready to install the new ****.
I decided to replaced my wore out stock **** with another stock leather beauty I was lucky to find "in perfect condition" right here on the corvette forum. "Thanks to (grinditout)
Sure looks purty now!!!
"I love the forum!!"
Old Aug 7, 2008 | 06:01 PM
DonF's Avatar
DonF
You are lucky, I had to drill mine out, what a pain.
To ZF 6 shift knob
