Transmission TV cable removal?
Old Jan 5, 2008 | 10:54 AM
93cruiser's Avatar
93cruiser
Default Transmission TV cable removal?
Can anyone enlighten me on the correct method of removing the TV cable from ther auto trans. I am removing the transmission to replace the front and rear seals. I am just about ready to remove the tranny. Thanks for any advice. The car is a 93 vert.
93cruiser
Old Jan 5, 2008 | 11:11 AM
Pete K's Avatar
Pete K
93cruiser
The tv cable for your 93 is obsolete. Therefore, I suggest the following:
drop the pan and pull the 2 tem mm bolts that retain the tv cable bracket at the bottom of the valve body. Remove the 10 mm bolt on the exterior of the trans and carefully wiggle the cble out of the bracket and trans. This will allow it to come apart without changing the adjustment. When reassembling, 87 INCH pounds is the correct torque for the 2 bolts that go into the valve body. Snug is good enough for the exterior bolt.
Old Jan 5, 2008 | 11:38 AM
93cruiser's Avatar
93cruiser
Thanks Pete. Did not realize the cable was obsolete. This forum is a tremendous resource. I would have screwed this up for sure.
93cruiser
To Transmission TV cable removal?
