Headlight motor question..............
Old Jan 6, 2008 | 04:00 AM
Z51JEFF's Avatar
Z51JEFF
Default Headlight motor question..............
Ive got a 91,when the headlights are turned on the headlight motors on both sides continue to run for several seconds once the headlights are in the park position,up or down.If the motors continue to run in the park position is it screwing up the gears.The cars only got 7,000 miles.Thanks.
Old Jan 6, 2008 | 08:36 AM
Sam Lam's Avatar
Sam Lam
You would do yourself a favor by posting this in the "tech" section of the forum. I have seen many postings on this topic in that section.
Old Jan 6, 2008 | 06:56 PM
jimg's'93's Avatar
jimg's'93
You need to replace the delrin bushings in the motors. It's a pretty easy and cheap fix.
To Headlight motor question..............
