opti
Old Jan 6, 2008 | 08:32 AM
GS023's Avatar
GS023
Default opti
Anyone ever seen or tried one of the Accel opti-sparks? Are the any better than the GM units?
http://www.accel-ignition.com/Produc...minselection=5
Old Jan 6, 2008 | 10:34 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Everything I've ever read on this site says stay away from Accel.
If it was me, I'd go with the new MSD unit.
Old Jan 6, 2008 | 11:26 AM
94z07fx3's Avatar
94z07fx3
Old Jan 6, 2008 | 04:29 PM
stranded's Avatar
stranded
Has MSD addressed the issue with the bolts coming loose? I think it was the rotor bolts.
Old Jan 6, 2008 | 07:44 PM
383_Proof's Avatar
383_Proof
good question
Old Jan 6, 2008 | 09:02 PM
ROB502's Avatar
ROB502
Default Opti
All Opti SUX!!
Old Jan 6, 2008 | 09:07 PM
RollaMo-LT4
Originally Posted by ROB502
All Opti SUX!!
Good for you............ that was very helpful...........
Old Jan 6, 2008 | 09:19 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I have an MSD Opti. According to MSD there are no issues with current builds. According to a few users on CamaroZ28 forum they had rotors come off during the first few hundred miles due to the screw coming loose.
It is recomended when you buy one to remove the distributor cover which you need to anyway to install the O-ring, and then simply remove the screw holding the rotor in place and put some red locktite on it and be done with the hazard.
I think the MSD Opti is a quality product and just went through some first run problems. I don't see many people reporting problems with them any more. If you have the money, go with the MSD, if not enought cash then get a factory vented model.
Old Jan 7, 2008 | 05:00 AM
wilsonbh's Avatar
wilsonbh
I just changed out my Optispark and installed a MSD. I held in my hand several other brands and without question, the MSD was a better made unit. It is also the most expensive but not by an unacceptable amount. To me, a couple of hundred more dollars to get a unit known for quality and longevity is well worth the extra money.
Billy
Old Jan 7, 2008 | 11:49 PM
jabez's Avatar
jabez
MSD is the way to go.
Old Jan 8, 2008 | 06:24 AM
GS023's Avatar
GS023
What were the issues (other than the rotor coming loose) with the early MSD's, if I were to find a used one?
Old Jan 8, 2008 | 03:09 PM
IcemanZ06's Avatar
IcemanZ06
I've got a dynaspark on my 92 and its doing great. The dynaspark is a re-engineered optispark that eliminates the majority of the weak points on the original opti design. They are quite costly but I'm happy with mine.
Old Jan 8, 2008 | 11:16 PM
biggrizzly's Avatar
biggrizzly
If you do a search on Z28Camaro.com on MSD you will find lots of users comments. The only other thing was the initial units came with a regular round Oring versus the square rubber gasket type Oring now supplied. Many users could not get the old Oring to stretch enough to get into the groove properly and could not seal the Cap onto the aluminum body of the opti. I hear others that had not trimmed their cam indexing pin enough and had problems, but that was not an opti issue.
I think all the old ones are out of the system or already installed on cars now.
Old Jan 9, 2008 | 03:54 AM
rubyred93's Avatar
rubyred93
I've got a DynaSpark also....no complaints. After 2 GM units failed I refused to buy another one.
Old Jan 9, 2008 | 04:42 AM
SK.LT1's Avatar
SK.LT1
Old Jan 9, 2008 | 04:45 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Dynaspark here - however I think they are out of business. Do a search and you'll find several folks that have come up empty looking for one.
If I had to do mine this year I'd get the MSD.
To opti
