"I thought the cam was .415 (as you say). And, you can not change it's "gross lift". I would think the cam lift multiplied by the rocker ratio would equal the valve travel (in inches)."
Right formula; wrong starting number.
.415 is the lift (at the valve) with stock 1.5 rocker
Cam (lobe ) lift is as stated .280 ish.
So, .415 x 1.5 = .6225" of valve travel for a stock '89 intake valve
And .415 x 1.6 = .644" of valve travel for a stock '89 with 1.6 rockers.
Effectively, this would be the same valve travel as if you'd left the stock rockers on the car and changed to a cam with .443 (intake) and .459 (exhaust) lobes. And, since head flows are based on cam lift (right?), then you need these numbers to predict flow.
We are saying pretty much the same thing -- except for the gross lift part.
gp
The .415 number is the number using 1.5 rockers. It is not the lobe lift, as stated by rodj. Most all cams you find give the net lift with a factory rocker ratio. Since most (maybe all, I don't know) sbc engines left the factory with 1.5 rockers, most all aftermarket cams for these engines give the lift numbers figured with 1.5 rockers. Sometimes you will see a cam that gives you both lobe lift and net lift (aka valve travel). The LT4 engine left the factory with 1.6 rockers (technically it isn't a sbc), therefore most of the time when you see an LT4 hotcam being sold it is advertised with the lift from using 1.6 rockers.
It really is strange, you would think all cams would just advertise the lobe lift, but it isn't so. Just one more thing that could be simpler than it is. I know that with 1.7 rockers you can run into retainer and spring clearance problems, you would need to be extra careful on spring and retainer choice. With a stock L98 or LT1 you can run stock springs with 1.6 rockers, but I don't think you can get away with 1.7 rockers. As always, as lift increases there is more potential for piston to valve clearance issues, but if you are talking stock L98 cam, heads and pistons then there would be no problem. The other issue is that you need narrow body rockers, and self aligning if you aren't using guideplates. I don't know of anyone who makes narrow body 1.7 sbc rockers. You would also need to check the pushrod length. I think till you go through all that trouble you would be better off to swap out the cam and run 1.5 or 1.6 rockers to get the desired lift.
C4 of Year Winner (appearance mods) 2019
Originally Posted by rodj
" you would be better off to swap out the cam and run 1.5 or 1.6 rockers to get the desired lift."
that is the general agreement across most of the performance forums.
Does this mean 1.6 rockers are kindofa waste of time or just don't use 1.7's?
One reason I say this is because on stock '89 heads, the difference in flow from .4 lift to .5 lift increases from 185cfm to only 195 (per TPiS). 1.6 rockers would get you 5cfm.
I'm thinking woopdeedoo.
