need injector constant from LT4 GS corvette
Old Jan 7, 2008 | 08:13 PM
Z06_BluByU's Avatar
Z06_BluByU
Default need injector constant from LT4 GS corvette
Can someone please post the stock injector constant from a 1996 GS corvette ECM bin?!?1 thanks!!
Old Jan 11, 2008 | 05:13 PM
93Blackrose's Avatar
93Blackrose
27.00 (With TunerCat)
Old Jan 11, 2008 | 08:19 PM
96GS#007's Avatar
96GS#007
27. To be [very] specific, when opened with LT1 Edit (for OBD II), my stock flash file has 26.987
Old Jan 14, 2008 | 07:49 AM
Z06_BluByU's Avatar
Z06_BluByU
thanks! Thats weird in that I thought it had stock 26 lb injectors.. (or was it 28lb).
Old Jan 14, 2008 | 10:19 AM
96GS#007's Avatar
96GS#007
The injectors are rated at 28lbs but that rating is at 43.5psi. The injector constant in the programming is a function of the rated flow and the actual fuel pressure. My guess is that the GM engineers took a look at a sample of engines/fuel systems during development and found that on average the fuel pressure at WOT is ~40psi. A 28# injector at 40psi flows ~27#. IIRC the fuel pressure spec is 38-43 at WOT, so 40 makes sense.
Old Jan 14, 2008 | 02:48 PM
Z06_BluByU's Avatar
Z06_BluByU
thanks!
To need injector constant from LT4 GS corvette
