Door Ajar Problem on 95
Old Nov 28, 2001 | 12:35 PM
Keith95Coupe's Avatar
Keith95Coupe
Default Door Ajar Problem on 95
I am getting the Door Ajar light flickering when going over a bump. Sometimes the hatch lights flicker also. Anyone know what causes this? TIA.
Keith
Old Nov 28, 2001 | 02:43 PM
Nilla Ice's Avatar
Nilla Ice
Default Re: Door Ajar Problem on 95 (Keith95Coupe)
Keith
keith,
Welcome aboard fellow houston fbud! Hope you find the forum as helpful as I have!
Tony
Red Dwarf's Avatar
Red Dwarf
Sounds like one of you D/A switches is giving up the ghost. Try exercising them & see if that corrects the problem. Some say that are adjustable & can be pulled out slightly. If you determine they have to be changed let me know as there is a way to do it without removing the door panel. :cheers:
Old Nov 28, 2001 | 02:50 PM
SunCr's Avatar
SunCr
Mine did this after new door seals and I had to replace the switches. I know this isn't the best description but they are self adjusting with kind of a post or rod within a post and the first time you shut the door (after installation) the outermost rod compresses (it's a pressure fit) and then the innermost rod compresses shuting the switch. The outermost rod remains in a set position until the seal wears and then it compresses a little bit more to maintain correct operation of the switch. If the outermost rod is completed compressed now and your seals are worn you are probably getting some movement within the switch; hence the flickering.
Old Nov 28, 2001 | 03:15 PM
Keith95Coupe
Default Re: Door Ajar Problem on 95 (Nilla Ice)
Thanks Tony. I find these folks very knowledgeable and helpful.
Old Nov 28, 2001 | 03:26 PM
Keith95Coupe
Default Re: Door Ajar Problem on 95 (lou sylvestri)
Thanks for the info. I feel the switch on the driver's side is faulty, either that or the wiring is loose. I tried to remove the switch to check it with a multimeter, but I failed. Much worse, I removed the two screws and found the backing plate has the threads for the screws. It was fun (NOT!) getting it back together. I would be greatful if you would let me have your secret for replacement.
Old Nov 28, 2001 | 03:29 PM
Keith95Coupe
Default Re: Door Ajar Problem on 95 (SunCr)
This sounds exactly like the problem I have. All the seals and weatherstripping are going to need replacement. This car was apparently parked outside for quite a long time. I am looking to restore the car to showroom condition. Thanks for the info.
Old Nov 28, 2001 | 09:47 PM
Rich_01659's Avatar
Rich_01659
the center of the switch should be a sliding pin. use some needle nose pliers and work it out a bit.
Rich
Old Nov 28, 2001 | 09:54 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Re: Door Ajar Problem on 95 (Rich_01659)
I replace these all the time at work. I remove one bolt and insert a pick in to hold the plate in place, then I remove the other bolt and hold the pick and pull the switch out and unplug it. Then install the new switch and put one bolt in and then remove the pick and install the other.
If the plate falls down, guess what you have to remove the door panel to get it.
Old Nov 28, 2001 | 10:40 PM
Admiral Fairway's Avatar
Admiral Fairway
If your lights are flickering when you go over a bump, chances are that it is your hatch switch. Remove the rear trim and bend the bracket holding the switch up a little, the pin that pushes the switch closed is problably not closing the switch all the way. I had this problem in my '94, the bracket got bent by using a hatch vent.
To Door Ajar Problem on 95
