Shifter Trouble
Old Jan 8, 2008 | 07:44 PM
Black_Vette's Avatar
Black_Vette
Default Shifter Trouble
I have a 86 4+3 speed Vette and I cant put my car into reverse any ideas ??? My shifter lockout seems like its stuck and not doing anything. Is there a way to repace this or does it involve changing the whole shifter ???
Old Jan 8, 2008 | 08:08 PM
dukecebrelli's Avatar
dukecebrelli
Mine too was getting locked up- I found that the bracket that holds this cable in place was hanging up slightly on the heat shields under the floor boards, right over my headers- I would check the cable and make sure its free- not hung or in any wierd curves causing the cable to get stuck at certain angles- I think also- you can remove the center console to reveale some bushings or a retainer for the cable...
Old Jan 8, 2008 | 08:18 PM
Black_Vette
on my shifter it seems that the black ring you pull up on to put the car into reverse has broken away from the shifter, is this possible ???
I took the cover off the shifter and it seems that when I pull up on the reverse lockout its not pulling the reverse pin up far enough.
Old Jan 8, 2008 | 08:22 PM
dukecebrelli
oh- we def. have diff. shifters- not a clue sorry
Old Jan 8, 2008 | 10:48 PM
Curveit's Avatar
Curveit
Sometimes it's the Clutch master or slave cylinder. They'll go into 1st but are reluctant going into reverse.
To Shifter Trouble
