Power Steering Cooler Question
Old Jan 8, 2008 | 08:14 PM
Sidney004's Avatar
Sidney004
Default Power Steering Cooler Question
Are both lines low pressure or is the inlet(driver side) high pressure? The reason I ask is that I am replacing a leaking cooler. When I disassembled mine, I detached the cooler from the hose, leaving the leak free o-ringed flare nut fitting in place. The used replacement has the hose attached to it with a real nice double crimp on the cooler side and flare nut o-ringed fitting on the other end. Should I preserve this assembly or (my preference) detach the hose assembly and reattach using a conventional hose clamp?
Old Jan 8, 2008 | 10:20 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default hoses
I think the double crimp and the o-ringed end are both low pressure.
The idea is to cool the fluid before it enters the reservoir. not as it enters the rack.
I am in the process of installing the serpentine system from an 87 corvette with the cooler into my 57 chevy pickup.
Old Jan 9, 2008 | 07:57 PM
Sidney004's Avatar
Sidney004
Thanks.
Old Jan 10, 2008 | 03:40 AM
schrade's Avatar
schrade
Where did you get your replacement cooler?
I got a tranny filter mounted right now (with clamps; no leaks). I attached extra hose to the existing ends, to be able to configure to original when I get the original fixed, or a new one ($300 from Eck)...
To Power Steering Cooler Question
