Why remove the AIR pump?
Old Nov 28, 2001 | 02:19 PM
Camvette's Avatar
Camvette
Default Why remove the AIR pump?
I am looking to see the advantages and what parts are necessary to make the modification.
:cheers:
Old Nov 28, 2001 | 02:51 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Why remove the AIR pump? (Camvette)
Why? Why, indeed! It depends on what you want from your car. The pump absorbs a few horse power and weighs a few pounds. By itself, I would not expect that you'd see much of a difference by the removal of the pump. As a part of a comprehensive weight reduction and perfomance adding effort, it is a small step in a long list of things you can do. I bracket race at least once a week during the season. I have a long list of things I want to do. Removing the AIR pump isn't on the list. My advice is to determine what you want from the car (performance and drivability), make a plan, and persue it. Have fun!
Old Nov 28, 2001 | 02:55 PM
Jim-K's Avatar
Jim-K
I want to remove it for two reasons: 1. I want to change to long tube headers and true dual exaust and wont have the air fittings anymore, and 2. I can't stand the racket it makes. Otherwise, I'd probably just leave it.
Jim-K
Old Nov 28, 2001 | 03:12 PM
Nathan Plemons's Avatar
Nathan Plemons
The LT1 cars have electric AIR pumps, so it's not even a big power issue. I just removed mine because I went with longtubes. I could have got the ones with AIR fittings, but it's not gonna pass emmisions anyway, so I might as well clean up the engine compartment as much as I can.
In my case it certainly wasn't for weight, the LT1 pump weighs about 3 ounces.
Old Nov 28, 2001 | 04:54 PM
pfast89's Avatar
pfast89
Default Re: Why remove the AIR pump? (Jim-K)
I took mine apart and removed the fiber-looking fins from the inside. Now it's just a pulley that's there for the vehicle inspection. I also have long tube headers. The modified AIR pump is all that's left of the emmissions stuff (aside from Cat). It has passed every inspection on the first go
Old Nov 28, 2001 | 05:04 PM
notbob's Avatar
notbob
Default Re: Why remove the AIR pump? (pfast89)
So they actually open the hood at your inspections?
Heh here in Ohio they might look under your car, I've failed 3 times... everytime they look under everyone else's car... but not mine ;)
I guess they figure if he can afford a vette then why bother it's probably in good shape.
It failed the first time by .02% of CO talk about some bs... since then it blew it's engine on the third time and had to be coherced to the place where she's still awaiting the new engine hehe.
Old Nov 28, 2001 | 11:14 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I've STILL got the entire set up on my car with the long tubes.
Saw no reason to take it off. Why butcher the car more, for no reason.
I want to keep it as stock as possible :D
Old Nov 28, 2001 | 11:33 PM
Black87c4's Avatar
Black87c4
Default Re: Why remove the AIR pump? (mackeyred96)
>>It failed the first time by .02% of CO talk about some bs... since then it >>blew it's engine on the third time and had to be coherced to the place >>where she's still awaiting the new engine hehe.
Did it blow during the emission test? I know some states use something like dynamometer emissions test i think. I've read of alot of cars blowning up because of this test. We don't have emission test here in OK (yet), think my next step is to remove all of the emission equipment on my vette just to p$ss off the EPA :mad . Think I'll also go outside and start every gas burning engine that i have and let them run for a little while :D
Old Nov 28, 2001 | 11:43 PM
pfast89's Avatar
pfast89
Default Re: Why remove the AIR pump? (notbob)
notbob,
Yep, they do a visual inspection to ensure all the factory emmission equipment is still intact. I slide by since they don't see any capped-off hoses or tubes. I've thought about the AIR pump replacement pulley that Corvette Central sells; but it's too obvious. BTW, I have the TPIS coated headers without the AIR tubes. I tell them they are stock aside from the coating. I take it to the quick-lube type places for inspection. Last thing I want is an ASE certified Mechanic doing the inspection.
Old Nov 28, 2001 | 11:45 PM
pfast89's Avatar
pfast89
LOL, your signature doesn't reflect this comment!
Old Nov 28, 2001 | 11:50 PM
scorp508's Avatar
scorp508
I removed it because.....
A). Mine was starting to go (howling bearings).
B). It was cheaper than a new pump.
C). It cleaned up the engine compartment a lot.
D). If there is even 1 HP freed up, then great!
Old Nov 29, 2001 | 12:55 PM
notbob's Avatar
notbob
Default Re: Why remove the AIR pump? (Black87c4)
The night before it blew I had taken it out to show a buddy of mine on a local backroad stretch that is a blast... I can take it from the T-Junction up to around 100 and coast back down before I get back to my house... well I did my usual and the car felt soft as hell... I figured it was the weather and the fact I was tired so I thought nothing of it.
I read you're supposed to warm the car up before emissions, so I let it idle for about 15-20 mins before heading out to the test... it felt like it was ******* a bit but I wasn't worried about it.
It goes through the test...took forever and a day, they gave me my results... it failed 4 times worse then ever before. I tried to drive it out of the parking lot... then I looked down at the heat and saw well over 200 degrees... I was pissed the damned monkey that worked there didn't notice the temp and stop the test because it was obviously doing damage.
But of course they're not liable for being stupid, had I seen temps anywhere near as high as it got I would have stopped right there and towed the bitch home or to my mechanic and fixed it before it damaged the heads.
I was able to drive it to my mechanic but it took some serious cohersion (can we say sitting at a light in N and dropping to D hehe, and jumpin the railroad tracks at 35 so I don't get stuck)
To Why remove the AIR pump?
