700R4 EXT Housing Bushing
Old Jan 8, 2008 | 09:34 PM
1irishprince's Avatar
1irishprince
Default 700R4 EXT Housing Bushing
Have an 86 coupe with a 700R4 that has a little more slop than I like where the driveshaft enters the extention housing. I seem to remember reading somewhere that there is a bushing in the tail housing that sometimes gets spun out...and they make oversize bushing just for that...and might take out the rest of the vibration I get at high speeds. The rear oil seal hasnt started leaking yet, so I think I've caught it early. Any thoughts???
Old Jan 9, 2008 | 12:13 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default bushing
1. buy a new seal and replacement bushing, and keep going.
2. an oversize bushing compensates for a worn yoke.
3. If your driveshaft yoke is worn, replace it and install the proper bushing.
4. If your bushing is going south, you probably need a front u-joint on that drive shaft.
Old Jan 9, 2008 | 03:56 AM
bigwave71's Avatar
bigwave71
Old Jan 9, 2008 | 06:07 AM
1irishprince
Is it fairly easy to replace? What I remember reading is its oversize only on the OD(once its spun out, the alluminum housing has too much play to hold the new bushing) All six u-joints only have a couple hundred miles on them, along with the rear hubs...the rear diff still feels tight. There shouldn't be any noticable movement in the shaft at the tranny when I move it by hand, but there is....
Old Jan 10, 2008 | 07:29 PM
Pete K's Avatar
Pete K
Rear tailhousing bushing do wear heavily. They almost never spin though. High milage transmissions do tend to spin the case bushing, and they have an oversized bushing for it, but the case needs to be machined.
Old Jan 10, 2008 | 09:27 PM
1irishprince
That's probably what I read...Haven't taken the tail off yet though. So, if it's the case, I would have to pull the tranny, right. I mean the extention housing's bushing is the only one I could replace without having to pull the tranny, or is the case bushing accessible with the tail pulled off??
Old Jan 10, 2008 | 09:46 PM
Pete K's Avatar
Pete K
True. The case bushing requires total, and I do mean total, disassembly to access. When I do a build, the case bushing is the very first thing I install in the bare case.
After removing the output housing (tailhousing) wiggle the output shaft up and down. If it wobbles more than 3/8 inch, case bushing is shot. Normal play on a good bushing is approx 1/8 inch up and down wiggle.
Old Jan 10, 2008 | 09:56 PM
1irishprince
Thanks Pete. If the play in the case is not too bad I will try and replace the tailshaft bushing. Is that an easy procedure. Is it "pressed" on the shaft or in the housing?
Old Jan 10, 2008 | 10:04 PM
Pete K's Avatar
Pete K
It is pressed in the housing, and is easily changed. Put it on the bench with the rear facing up. Once the seal is pryed out, the new bushing can be used to drive the old bushing out at the same time it is driven in. Find a correct size driver, or improvise a socket installed backwards on an extension, and gently drive it in straight.
To 700R4 EXT Housing Bushing
