Superram/vortec heads which cam/TB?
Old Jan 9, 2008 | 12:00 AM
85L98-84L83's Avatar
85L98-84L83
Default Superram/vortec heads which cam/TB?
I just got my credit line increased at the bank . Now, I have a superram, TPI vortec intake, and will buy vortec heads for my 85 vette. Which cam should I get, the 219 superram cam, ZZ9, or other and which throttle body: holley, BBK, and which size, 52mm, 54mm, 58mm? It will be installed on the original 350. This is a super budget vette:
85 vette $4300
paint $899
TT 2's wheels $1200
wing $200
K&N $25
test pipe no cat $54
air foil $9
Old Jan 9, 2008 | 12:55 AM
CRV3TT3's Avatar
CRV3TT3
Go with the LPE 219, save your $200 and avoid getting the wing, and you wont need to but a throttle body unless you are increasing cubic inches.
Old Jan 9, 2008 | 01:56 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Especially about the wing!
Old Jan 9, 2008 | 07:11 PM
85L98-84L83
The wing is already in my garage
Old Jan 9, 2008 | 09:44 PM
Kevin Woods's Avatar
Kevin Woods
Well.....I got a Holley TB that came with a Super Ram system that I just bought. Really, I don't think you can do much better than getting the TB that came with the system.
PM me if you're interested.
KW
Old Jan 9, 2008 | 11:10 PM
vader86's Avatar
vader86
219 cam, keep the stock TB.
Old Jan 9, 2008 | 11:39 PM
3 pedals's Avatar
3 pedals
The 219 cam is a roller cam, to use it in your 85 block you will have to use a set of retro roller lifters. There are flat tappet cams that should work OK.
Old Jan 9, 2008 | 11:46 PM
85L98-84L83
Maybe I should just sell my superram and vortec intake and be a purist and keep it stock?
A little secret: purist is a fancy word for cheapskate
Old Jan 10, 2008 | 09:22 AM
Kevin Woods
Maybe I should just sell my superram.....
Well......if you decide to go that route, PM me first.
I would be very interested in exactly what parts you have and your asking price !!
KW
Old Jan 10, 2008 | 09:43 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
A flat tappet cam with 219 like specs should be fine. Do a search on www.summitracing.com
Old Jan 10, 2008 | 08:28 PM
raeke1's Avatar
raeke1
What is a 219 cam ??? what the spec???
Old Jan 10, 2008 | 08:34 PM
Road Agent's Avatar
Road Agent
Are you really that stupid? What a dumb azz statment!
Old Jan 10, 2008 | 09:00 PM
BADDUCK's Avatar
BADDUCK
I should have known when I saw the Wing & the Air Foil this was gonna be a weird thread!
Old Jan 10, 2008 | 09:18 PM
raeke1's Avatar
raeke1
I know 219 is dur @50" but is a good lift and surp for stock l98 cast head and stock tpi???
Old Jan 10, 2008 | 10:26 PM
3 pedals's Avatar
3 pedals
The specs for the 74219 cam - Duration @ .050 219/219. Lift .506/.525. Lobe separation 112. Lingenfelter use to sell flat tappet cams - I don't know if they are still available. 74212 Dur @.050 214/224. Lift .443/.465. Lobe separation 112. 74213 Dur @.050 224/234. Lift .465/.488. Lobe separation 112. The 212 was designed for use with stock or High Flow runners, offering strong mid-range torque and a smooth idle. The 213 and 219 are intended for 383/406 cid enginges in conjunction with the SuperRam intake. These cams have a choppier idle. By the way - I put a wing on my vette because I like it and I don't care if anyone else does!
Old Jan 10, 2008 | 10:53 PM
Kevin Woods
Originally Posted by 3 pedals
.....The 213 and 219 are intended for 383/406 cid enginges in conjunction with the SuperRam intake......
And they worked amazingly well with stroked, Super Rammed LT1 engines, too !
KW
Old Jan 10, 2008 | 10:56 PM
85L98-84L83
Wings rock
To Superram/vortec heads which cam/TB?
Old Jan 10, 2008 | 11:00 PM
85L98-84L83
Thanks for your constructive imput
There is no need to be mean, you should reread the rules of this forum or did you just click I agree
We are all corvette enthusiasts here, so just try to get along.
Old Jan 10, 2008 | 11:03 PM
85L98-84L83
Thanks for your help, and saving me about $350 on the TB.
Old Jan 13, 2008 | 01:55 AM
opel's Avatar
opel
The S/R is not a direct bolt on for the Vortec intake. The Vortec has a different bolt pattern than stock so some of the intake bolts will be under the S/R runners and there will be interference. It can be made to work but you have to be willing to grind on the S/R runners and replace two of the intake bolts with ground down hex heads bolts. Make sure you use the correct length intake bolts, they need to be just the right length for the correct squeeze on the intake gaskets.
I'm using a Crain cams 113801 cam on my 85 388ci http://www.cranecams.com/index.php?s...01&lvl=2&prt=5 as 3 Pedals stated the 85 is a non roller engine so you can not run the 219 roller cam with out going to a retro roller set up which is expensive.
I like the 113801 it gives me good performance, but for me I'm going with a roller set up and the 219. I have had numerous lifter problems and the rollers should take care of that.
When you buy the Vortec heads make sure you get heads that have had the mods done to them that allows you to run bigger cams. The stock Vortec heads can only run something like 465 left before there's spring bind. And get the spring the cam manufacturer recommends.
You will need to have a chip burned, the stock chip will not be able to handle all the changes.
Dave
