help me corvette 85 nitrous
Old Jan 9, 2008 | 10:47 AM
MAXsuperam's Avatar
MAXsuperam
Default help me corvette 85 nitrous
Hi all I want to put a nitrous kit in my 85 with a boost to 100 hp
But I have the following modifications
Accel super RAM
Injectors 24 LBS / h
And a chip hypertech
And I know that we can not only put a bullet aftermarket
With a special kit because our self detonation
And I did not chip stock I buy my vette like that
I must change of emc by a reproglamable
Knowing that later I would change probably cam
In the case is what emc choose
tank you
Old Jan 9, 2008 | 10:59 AM
CRV3TT3's Avatar
CRV3TT3
What did you just say? All i understood was that you have a superram, 24lb injectors, and you want nitrous.
Old Jan 9, 2008 | 11:27 AM
MAXsuperam's Avatar
MAXsuperam
Yes it is the place I want a kit and more nox
Regrettable, my English is not good I try to edit my profile to say that I veins of france, but I can not
Old Jan 9, 2008 | 11:52 AM
mn_vette's Avatar
mn_vette
You will want to take out the Hypertech chip.
Everything else looks good to go. Just make sure you get a WET Nitrous kit.
Old Jan 9, 2008 | 12:13 PM
MAXsuperam's Avatar
MAXsuperam
No. I would like to have a chip stock car I buy my vette with a chip hypertech ,ok tanks kit is then type
http://www.nitrousdirect.com/corvett...rous-kits.html
Old Jan 9, 2008 | 12:57 PM
mn_vette's Avatar
mn_vette
Hyper tech chip is BAD. It will break your engine with nitrous.
No stock chip, try this instead MSD Digital 6 http://store.summitracing.com/partde...5&autoview=sku
This will retard your timing when you run nitrous, then your engine is ok.
Maybe you should look at a Bottle Heater too. http://www.nitrousdirect.com/bottleheaters.html
Old Jan 9, 2008 | 01:15 PM
MAXsuperam's Avatar
MAXsuperam
Thanks mn vette actually is a solution to delay the ignition thanks again
Old Jan 9, 2008 | 03:25 PM
lead foot 85 vet's Avatar
lead foot 85 vet
superams don't work well with a wet shot.........the corners are too tight, the gas will seperate and you'll have lean cylinders.........direct port injection is the only way.
Old Jan 9, 2008 | 04:38 PM
MAXsuperam's Avatar
MAXsuperam
ok tanks
Old Jan 13, 2008 | 05:35 PM
MAXsuperam's Avatar
MAXsuperam
The box serves MSd Digital 6 alone has delayed the ignition at the shot of nitrous or else it is necessary items please your answers
Old Jan 20, 2008 | 02:51 PM
MAXsuperam's Avatar
MAXsuperam
To help me corvette 85 nitrous
