My UNDERHOOD lights stop coming on several weeks ago. I have
searched my Owners Manual for a possible fuse replacement, but
there is nothing listed. What is the remedy for problem? Thanks
There is a 5A fuse that is in a small holder attached to the round vacuum tank that sits in the driver's side headlamp well. Chances are that the fuse is blown.
Each light has its own mercury switch that turns them on and off when the hoos is raised/lowered, so if both lights went out at the same time, it would be unlikely that these switches are bad.
