Need Help With A Leaking Trans Pan
Old Jan 10, 2008 | 01:58 AM
eguyett1985's Avatar
eguyett1985
Default Need Help With A Leaking Trans Pan
I recently installed a Moroso aluminum transmission pan on my 700R4 and I used a Neoprene gasket and filter from Napa, I installed the gasket dry like I've done on other transmissions in the past and torqued the bolts to the spec in my FSM. After I broke my new engine in and while the car was up in the air I noticed some seepage from the front of the pan between the gasket and the pan and the gasket and the case, so I cleaned it up with brake cleaner and went back and snugged the bolts all up again but a little more snug than the first time and let the car just sit and the next day...still leaking...anyway, I took the pan off and checked it on a machinists surface plate and there was a very slight rock to it from side to side (only about .025) but I took it to a machine shop and had it surfaced just to be sure, got it back, checked it again and this time it was perfectly flat, I even compared it to my OE pan and it is straighter than that one. So I reinstalled it again, also with the gasket dry and looked at it tonight and it is still seeping... So now what? I thought the Neoprene gaskets were better than the cork so that's what I used and I have always installed the gaskets dry but now I'm wondering I should use sealer but I don't want to smoke the transmission by using it....any ideas?
Old Jan 10, 2008 | 03:24 AM
schrade's Avatar
schrade
Tough luck there, eguy...
I got a few pics in this thread; don't know if it will help tho', except for the grease (not sealer)...
http://forums.corvetteforum.com/show...ny+filter+swap
Old Jan 10, 2008 | 09:56 AM
Diger's Avatar
Diger
If it looks wet at the front of the pan then take off yor flywheel dust cover and check the front seal and or front pump gasket & o-ring for leaks. A small leak from there will run down to the pan and fool you.
Always look at a higher point where you think it might be leaking.
cooler line fittings, down shift cable, shift linkage. ETC
Old Jan 10, 2008 | 11:54 AM
eguyett1985
I just replaced the front seal when the trans was out and I did look up behind the converter just to make sure and everything there looks dry.
Old Jan 10, 2008 | 06:39 PM
HiRiser's Avatar
HiRiser
sure it's not the dipstick tube leaking? happened to me, I replaced the pan gasket twice before I found the dipstick tube leak
Old Jan 10, 2008 | 07:04 PM
rick lambert's Avatar
rick lambert
Hellava lot of difference between oil and tranny fluid, you know the difference. I'll tell ya, I hate Neoprene gaskets, my problem is they always seem to move, if you insist on using them put a little sealer on the corners and around the bolt holes. Give me the old cork gaskets any day, I always did what I suggested above, especially on pan and
valve covers, I simply put enough gasket cement on to hold them in place on the pan or cover, I usually installed the bolts in the pan or valve cover for alignment purposes..let it sit for awhile and then bolted it up, can't tell ya how many times I was able to re-use the same gaskets.....learned this when I ran solid lifters. And on the damn intake, thoughs Neoprene gaskets always moved....now the guys use The Right Stuff cement, which I haven't had to try yet.
To Need Help With A Leaking Trans Pan
