How many volts does your car run at?
Old Jan 10, 2008 | 02:31 PM
BTU83's Avatar
BTU83
Default How many volts does your car run at?
My 84 Corvette fell into the low 9's and now won't start.
Old Jan 10, 2008 | 02:57 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
You need an alternator! Should run at 14 volts!
Old Jan 10, 2008 | 03:00 PM
rick lambert's Avatar
rick lambert
First check your battery connections if they're OK have both the battery and alternator checked. 14.5 here.
Old Jan 10, 2008 | 03:57 PM
stifeout's Avatar
stifeout
about 15 volts here.
Old Jan 10, 2008 | 03:58 PM
StealthLT4's Avatar
StealthLT4
wow, yeah, definitely way low. 14.1 for me.
Old Jan 10, 2008 | 05:23 PM
Vette Gator's Avatar
Vette Gator
After starting, mine runs at 13.9
Old Jan 10, 2008 | 05:42 PM
Plasticman's Avatar
Plasticman
13.9 volts normally.
Old Jan 10, 2008 | 06:26 PM
dukecebrelli's Avatar
dukecebrelli
New batt. and alt.- 12.5 from the batt and 14.2 with alt. running
If your battery is good, I'd get that alternator replaced before you have to buy a new battery too!
Old Jan 10, 2008 | 06:32 PM
front royal vette's Avatar
front royal vette
ours run about 14.9 most of the time.
Old Jan 10, 2008 | 06:51 PM
BTU83's Avatar
BTU83
I was working on some projects that required keeping the power on for periods of time. I watched the voltage level slowly drop as I kept having to turn the car power on and off. I thought I would still be able to start the car afterwards to charge up, but I guess not. Is the alternator a hard change on this car?
Old Jan 10, 2008 | 06:52 PM
dukecebrelli
I'd have to say no
Old Jan 10, 2008 | 07:15 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
13.9 to 14.2 volts
Old Jan 10, 2008 | 07:33 PM
rick lambert
Alternator is simple to R&R...BUT, make sure you disconnect the battery first!
Old Jan 10, 2008 | 09:46 PM
Gary R's Avatar
Gary R
If you change it yourself, be sure to charge your battery for a while. If the battery draws too much, it can burn out your new alternator.
Old Jan 10, 2008 | 09:56 PM
95BLKVette's Avatar
95BLKVette
No way, it only puts out what it is designed for. The alternator circuitry varies the stator field strength electronically to regulate the output voltage and amperage under various load conditions. New alternators are designed to do this....no problem unless there is a short.
Old Jan 10, 2008 | 10:07 PM
brian84's Avatar
brian84
I have an 84 vette.
our alternators dont like 600 rpm.
mine only puts out like mid 12 at that speed.
700 rpm and up puts down a solid 13.5v
any rpm over 800 = a steady 14+ volts.
just for giggles before you buy a new alternator,
give your battery a FULL charge, on a good battery charger( 10amp )
and then try and start your car up,
check the voltage once its started
I just recently found out that alternators do not like to charge up exessively drained batterys. they just keep charged batterys from loosing the charge they already have.
so
apparently if you drian your battery past a certan point - it needs to be recharged by a dedicated bat charger - not the alternator.
I wonder if I could find a solar panil to mount on the dash and hook to the battery to trickle charge during the hot sunny days.
Old Jan 10, 2008 | 10:11 PM
Demonic85's Avatar
Demonic85
To How many volts does your car run at?
JLeatherman's Avatar
JLeatherman
84 alternators are notoriously weak. They are the dreaded 17SI series. GM took an alternator that didn't put out enough, and over-drove it with a smaller pulley to get enough juice from it. Makes it blow bearings and stuff fast, and they run hot. Check in the FAQ section on this site. There's a posting about changing to a CS series 120 amp alternator. That's what I've got in my 84 now and it's a very nice alternator. Can be found in junkyards on caddys and 90's trucks.
Old Jan 10, 2008 | 11:13 PM
Johns87's Avatar
Johns87
As Brian84 alluded to, Alternators only CAN produce power if the battery has a decent charge.
The battery has to energize the coils in the alternator, in order for it to charge properly.
Charge the battery and then check what is going on.
Take care, -John
Old Jan 10, 2008 | 11:55 PM
BTU83's Avatar
BTU83
Best place to buy a new alternator? Are they rather universal?
