Header install question.
Old Jan 12, 2008 | 07:41 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Default Header install question.
I've been looking over all the header post and think about installing them myself. I was wondering how high off the ground do you need to get the Vette. I saw some photos but couldn't really tell. If you had them install how much did it cost you for labor.
Old Jan 12, 2008 | 09:46 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Mine is up 8 inches and it was plenty of room.
That's 8 inches under the wheels. I have the car on wood blocks stacked up. So the wheels are sitting 8 inches higher than normal, as if it were sitting on the ground.
Old Jan 12, 2008 | 03:18 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Thanks 8" I can handle one person said 2 feet were needed to get this done. Time to give EM a call.
Old Jan 12, 2008 | 03:29 PM
jsup's Avatar
jsup
2 feet is rediculous. Here's one pic I have. These are 2X12s I cut down. Figure each board is 1.75 inches
I had plenty of room, way more than enough. Ignore the mess. It's 8.75 inches under the wheels.
Old Jan 12, 2008 | 03:36 PM
LouisvilleLT4's Avatar
LouisvilleLT4
I was the one that said that. Unless you're going to tear everything down to install them from the top, that's how much height you need to angle hooker 2151 headers up into place. Keep in mind the car starts about 4 inches off the ground.
Old Jan 12, 2008 | 03:46 PM
jsup's Avatar
jsup
I did mine from underneath with zero problems and more than enough room form what is in the picture.
Just thought of something.
You do have to take out the temp sensor on the passenger side head, it's a bitch to work around it.
Old Jan 12, 2008 | 08:11 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Thanks for the tip. 16" floor jacks and the wood blocks should get the job done.
Old Jan 12, 2008 | 10:12 PM
jsup's Avatar
jsup
If you get EM headers you'll have to grind down the side of the cross member. I just took it off and did it on the bench.
On the driver's side the oil cooler hose was up against the header. I ordered a new one from the local Chevy dealer. I cut the side that goes into the block short about 5/8 of an inch, that gave me about 1/4 inch or slightly more between the header and the oil cooler hose.
Those were the only minor mods I had to do. The grinding of the cross member was optional, as I had about 1/8 inch between them. I just wanted more clearance.
I'd take the cross members out to get the old exhaust out, as getting up there is a bitch with them in the way. BUT you have to bolt them back on BEFORE putting in the header on the passenger side. The driver's side isn't an issue.
Last thing, I went to Sears and picked up a 3/16---1/4 inch drive allen key. Made getting in that last bolt on the passenger side much easier.
Old Jan 12, 2008 | 10:43 PM
STL94LT1's Avatar
STL94LT1
None of this will be necessary on the OP's 95.
Old Jan 12, 2008 | 10:47 PM
jsup's Avatar
jsup
Sorry, if I had noticed that little detail I never would have responded in the first place.
I missed it was an LT1. Just assumed. Well, goes to prove what happens when you assume.
Old Jan 12, 2008 | 10:49 PM
STL94LT1's Avatar
STL94LT1
Hey, it's good information for the L98 guys.
Old Jan 13, 2008 | 02:11 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Thanks for the info anyway. I'll be calling EM Monday to place my order. Hey STL94LT1 its early but have you looked over Gateways schedule for dates you would like to meet. I've got a list six people so far plus some non forum members that want to go.
Old Jan 13, 2008 | 12:04 PM
STL94LT1's Avatar
STL94LT1
I work evenings, and will need to know ahead of time when everyone wants to go. I'll need to get the day off work pre-approved.
I just had some work done to my heads, and new rockers/guides/pushrods. The car is feeling really strong.
Old Jan 13, 2008 | 03:38 PM
vetteracer92's Avatar
vetteracer92
I've just used 4 of those rhino ramps from walmart. You'll need to take the driver side motor mount bolt and flip it around. The only pain was the alternator braces.
Old Jan 13, 2008 | 05:19 PM
Ed's lt4's Avatar
Ed's lt4
I just installed my EM's this week end. The worst part was getting to the upper driver side cat bracket bolt. I have a 6 speed (auto's may have more room) but one tip i can give is while your reversing the motor mount bolt let the motor down to give added clearance to loosen with a swivel socket then work it out the rest of the way with your fingers (do that one first). Some just cut the bracket off. you don't have to remove the alternator or bracket, just the a/c compressor and move aside
Old Jan 13, 2008 | 05:49 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Thanks for the tips. got some nice people on this board.
Old Jan 13, 2008 | 06:38 PM
STL94LT1's Avatar
STL94LT1
Yep, I used a cut-off wheel.
Old Jan 13, 2008 | 11:12 PM
LouisvilleLT4
It looks like that car is about 2 feet off the ground????
I couldn't get my headers past that sensor without grinding a few mm off the sensor's connector. I certainly didn't feel like draining the coolant to remove it.
I recommend making darn sure the primary pipes don't come too close to the frame anywhere, I missed where one of them bumped up against a little bump in the frame and by the time I noticed it was too late to dimple the pipe there because I had just had them coated. I ended up grinding off the corner of the frame.
Old Jan 14, 2008 | 08:31 AM
jsup's Avatar
jsup
Look under the wheel, there's 5 boards, 1.75 each.
Ah yes, I didn't have to drain since it was already done, they were new heads
So did I
To Header install question.
